K & N air intake vs stock intake
Is there any difference between leaving the stock air box open with a K & N air filter vs the FPK system? Please give me your thoughts.
Not really i dont think, they both suck in hot air that most people want to avoid.
I disagree. I noticed a lot more throttle response through the power band. Also, 3 previous times at Laguna Seca, I hit a consistent 101-103 on the front straight. With the FIPK, I hit 108 consistently, and it was under the same conditions as the previous time. Plus, my gas mileage has gone up 3-5 mpg. I consistently did 20-23 mpg, now doing 25-28 mpg. I thought it turned out to be money well spent.
i'm sold... where's a good place to order one? I see you can order them at autozone and pepboys.
PM sent.
Thanks for all the replies. I will probably get the FPK.
#7 (permalink) | |
went on a drive with veszna on saturday, and his car did seem to have a little more low end pull than the rest of us who were all stock. plus, it sounded a lot cooler, not to mention it looks nice in the engine bay. It sits in the very front passenger side corner and looks to get the most "cool" air possible and it has a plastic piece that looks like a heat shield. We talked about it a little at breakfast, and he did say you can notice some heat soak after a while. general consensus tho, was don't pull the top cover off the stock airbox. If you look inside the stock airbox, there's a partition in there. I'm not quite sure what purpose this serves, but I was thinking about cutting it out. "Hell on wheels" did this and even drilled some holes in the side of the airbox closest to the passenger side on the bottom. Right behind the passenger side headlight, there's a hole, that looks to direct some more outside air into the engine bay and could possibly add more cool air to the airbox, if those holes are drilled in the side. Not sure if it adds any efficiency, but it sounds a little throatier.
http://www.autopartswarehouse.com/pr...del_text=s2000
just found it at this website for 243.00 and shipping is free. |
just ordered it. and they charged me 17 bucks for tax, but gave a 10 dollar discount, with free shipping, I paid 250.00.
Wasabiman- I have seen other people route a flexible plastic pipe from the fender hole into the airbox. This means that it was still not drawing any hot air from inside the engine bay.
Yes, taking the cover off the stock box will do nothing but add some noise and probably become a vacuum for hot air, decreasing power.
According to a filter evaluation I read, the K&N does allow more air to pass. But, it also doesn't filter as well. Shouldn't be much of a problem if you change oil more often.
I was looking to purchase a K&N air filter for my car but I wasnt sure about back pressure. I am most likely a bit over-concerned but I am really wary of doing anything that will affect or offset the dialed in specific tolerances from factory.
My fear is that it will eventually create undue stress to the engine. Ive heard that when using a cold air intake to be truly careful of using low grade (cheaper) intakes because they will destroy an engine over time. Causing you to have ticking in the engine and burning up head-gaskets. Actually makes your engine run hotter when you have a cheaper setup not dialed in properly I believe. What is a really good cold air intake. That will not cause any of these problems or issues? Thanks Blurrrrrrr.... |
You mean change the air filter, right??
#16 (permalink) |
No, I believe the K&N filter is re usable. It must be cleaned and oiled
periodically. However, it is said to be less efficient at blocking smaller particles of dust than the good pleated paper filters. That is why the engines run a little better with the K&N. It's a trade off. That's why your oil may get a little dirtier, faster.
#17 (permalink) |
HondaOwnerSinceForEver
Just get a snorkle and leave everything else stock people ...jeez..Dont you trust honda engineers yet? I think they put a little bit more effort into this motor than any of us "geniuses" in here.lol
#18 (permalink) |
Honda isnt perfect no matter what the internet told you little boy. Since modding a car is so bad we should race. I just have a single tip exhaust CAUSE ITS MUCH LIGHTER THEN STOCK and a few small things under the hood. Itd be fun. You know me being a ricer and all vs you.
#19 (permalink) | |
#20 (permalink) | |
_____________________________________ >>>>>>>>>>>>>>>>><<<<<<<<<<<<<<<< |
#21 (permalink) |
#22 (permalink) |
Absolutely
#23 (permalink) |
dang frontline, of course honda engineers these cars to perfection, but if some of us want to open up the intake a little to get more performance what's the big deal? I am a believer in the k&n fipk since I've installed it, vinny was right about a little smoother throttle response and the gas mileage has gone up by a couple miles. Am I really hurting motor? I doubt it. Do I drive like a maniac and try to race every fool with a fart can? No... Is it fun to personalize your ride and hear the motor scream while carving the side of a mountain? Yes I think so. My car will most likely stay mostly stock with the exception of some lighter rims, but that's my decision isn't it? I'm just curious as to why you think you can down others and sit up on your high horse, and then say things like, "jeez i'm nice now." Please dude, it's getting old.
#24 (permalink) |
Well I am from pa so we are kinda far. We could always put up slips though see whos honda is more perfect. I will be going next week if weather holds.
#25 (permalink) |
Just Keyshia Cole it man....Let It Go
_____________________________________ >>>>>>>>>>>>>>>>><<<<<<<<<<<<<<<< Last edited by frontline762 : 10-13-2007 at 01:07 PM. |
#26 (permalink) |
There is a lot of discussion regarding air filters such as K&N, Amsoil etc. For those that want to learn a little more, here is an in depth article.
http://www.bobistheoilguy.com/airfilter/airtest1.htm
