Old 11-20-2007, 04:59 PM   #1 (permalink)
Jax Grafx S2K
Jax Grafx S2K's Avatar
Rear end
Why is the differential a weak point. Is it the gear or what that makes it weak?
Jax Grafx S2K is offline   Reply With Quote
Old 11-20-2007, 05:21 PM   #2 (permalink)
In-breedin'.
Old 11-21-2007, 08:55 AM   #3 (permalink)
Because it is designed by another company for cars with less HP. There is flexing that goes on in the housing I believe and this allows the gears to move slightly apart. The torque generated (as little as it is) will cause the ring to slip past the gear and the grinding occurs. This is just my theory, I do not have actual proof in my hands.
Old 11-21-2007, 01:05 PM   #4 (permalink)
Kalm_Traveler
Kalm_Traveler's Avatar
All the research I did supports this to the T. The case gets ripped apart because the differential itself shimmies around inside - thus putting stress on the case sideways rather than the way it was designed to hold things.
Old 11-21-2007, 01:54 PM   #5 (permalink)
Jagg's theory,
Many auto manufacturers do not build or design their own rear diff assemblies, yet it's rarely a failure related to application or design.
typically, fluid loss due to lack of proper maintainence is the reason for a differential's failure..
Go is correct that the rear is designed for less powerful applications,
but they're not really producing any less torque than what stewie has.
I believe that the rears are designed with too little backlash for a car with such a sportscar drivetrain. (personally, I"ve never seen a rear end with less backlash built into it than on an S2000)
They attempt to elilminate this issue via the dampening design of the driveshaft, and also up front at the clutch (i.e. clutch delay valve)....but for the really hard drivers, it's not enough.There's nowhere for the power to go before the ring and pinion are fully loaded, and wham! she snaps.
I understand why they use this weight and size saving design....but most beneficial things under a car have a drawback somewhere.
Bottom line, Stewie ain't got enough slop through the drivetrain, and sometimes under harsher circumstances, something's got to give.
just my opinion,
regards,
Old 11-21-2007, 02:04 PM   #6 (permalink)
'Pretty damned "jus' the facts m'am" opinion Jagg.
So, as usual, everybody'z aware'a this brand "X" manufacturer producin' Stewies rear . . except me. So I godda ask: Who makes Stewie's rear n' was it intended for a specific car 'r jus' put on a shelf for universally fittin' whatever came along?
Be well all,
Old 11-21-2007, 02:14 PM   #7 (permalink)
MarkZ28
Datsun used to use Fuji heavy industry rears and Subaru is now using the same rear ends, has been for a while to. I know its not the same company that makes the Miata's rear since I just changed fluids in both today.
MarkZ28 is offline   Reply With Quote
