Old 11-24-2007, 07:13 AM   #1 (permalink)
slowrodent
slowrodent's Avatar
oil/trans/fuel additives???
All,
Any additives that you swear by/at??
I'm running synthetics in engine/trans/rear/brakes, but I've wondered if any of the additives are useful or simply snake oil.
Lemme know what you think.
Thanks, Kevin
slowrodent is offline   Reply With Quote
Old 11-24-2007, 07:54 AM   #2 (permalink)
Nope.
Old 11-24-2007, 12:49 PM   #3 (permalink)
DJJSR
DJJSR's Avatar
Thanks, Kevin
I think using anything but Honda's MTF in the transmission may cause more harm than good. I really like synthetics, but I've been reading and hearing a lot of negatives about putting it in the gearbox. From what I understand it can cause the shifting to feel more "notchy" because the synchronizers are spinning too fast. (that may be over simplifying it)
Don
Old 11-24-2007, 02:31 PM   #4 (permalink)
slowrodent
slowrodent's Avatar
thanks for that input Don... I'll def. consider switching. I'm currently running Royal Purp 10w/30 in the trans (per their recommendation.) They claim that it matches the viscosity of the MTF pretty well. I may switch it out.. just to be safe.
Kevin
Old 11-27-2007, 03:39 PM   #5 (permalink)
s2ook
s2ook's Avatar
I use Amsoil MTF which is synthetic and AFAIK the only Honda approved MTF other than OEM. The notchiness has almost disappeared from the gearbox completely.
I also use a fuel additive - Redline SI-2.
Mods so far
Audio: Alpine 9857R; Alpine SWD-1600 underseat sub; Modifry DCI; Boston Acoustics RC620; Genesis Profile Two
Performance: AEM V2; Buddy club P1 Racing QF 13.42lbs front 14.41lbs rear; Toyo Proxes T1R 215-45-R17 Fr 255-40-R17 Rr; EBC Redstuff Fr/Rr; Goodridge stainless steel braided brake line kit (red); Cusco BMC brace; Krank Vents
Styling: Painted calipers; S2000 decals
Fluids: Amsoil 10W-30; Amsoil MTF; Almasol 607; ATE Super Blue brake fluid
Silverstone, The fastest S by far
s2ook is offline   Reply With Quote
