Old 11-29-2007, 10:01 AM   #1 (permalink)
SilverS2K422
B.A.M.F.
SilverS2K422's Avatar
Floor clutch??
any idea why i would have clutch problems at 50,000 miles. It sticks to the floor and is hard to push in. Please need help on this
Old 11-29-2007, 10:10 AM   #2 (permalink)
Raconteur
throw out bearing and pressure plate...are you the first owner?
Old 11-29-2007, 11:40 AM   #3 (permalink)
If not what has already been stated, check your fluid level. Our clutch is hydrolic.
Old 11-29-2007, 12:59 PM   #4 (permalink)
Raconteur
actually, now that I think about it...does the clutch release when it sticks at the floor? Can you shift gears or do the gears grind and you're not able to change gears? If you can change gears but the clutch pedal is on the floor, you might think about investing in a clutch and pressure plate (aw, go for it and get a lightened flywheel while you're at it) and a new throw-out bearing. If you can't change gears and the clutch pedal is on the floor, you need either a new clutch master or slave (or both) cylinder. As go said above, first check your fluid level in the clutch master cylinder. Hydraulic fluid has a distinct smell and look...are there any mysterious fluids on your driveway or garage floor? If you know the smell of brake fluid, you know the smell of the clutch hydraulic fluid...have you smelled that anytime lately? This should get you started...(and, btw, does this happen under heavy acceleration only or at any time?)
Old 11-29-2007, 08:11 PM   #5 (permalink)
Yeah it does and I hate it. It reminds me of all the problems I had installing the MC on the Cobra. That is three days of my life I will never get back.
Old 11-29-2007, 09:21 PM   #6 (permalink)
Vezna31
Vezna31's Avatar
Clutch fluid low or never been changed!
http://www.vezna.com
Old 11-29-2007, 10:33 PM   #7 (permalink)
SilverS2K422
B.A.M.F.
Thanks for the Replies
The Gears dont grind it shifts just fine, just the clutch stick to the foor but come back up, Actually if i take it up to high rpms the clutch feels normal for a lil bit??? dont know why....i kinda want an upgraded clutch anyways, any suggestions on what to get and what kind of money i will be spending?
Old 11-29-2007, 10:40 PM   #8 (permalink)
Vezna31
Vezna31's Avatar
I'm about to replace my clutch next week. I'll post what I pay for parts.
Old 11-29-2007, 11:55 PM   #9 (permalink)
SilverS2K422
B.A.M.F.
Hey sounds good thanks
clutch, honda, s2000, sticks
