Old 12-21-2007, 03:17 PM   #1 (permalink)
SoMe0nE2tAlK2
Send a message via AIM to SoMe0nE2tAlK2
Clunking sound going into 1st gear
My car's only about 3 weeks old.
I noticed that whenever I'm stopped and I put the car into first I hear a clunking sound from the transmission. I was wondering whether or not this was normal. And i made sure I had the clutch all the way down. It makes the sound as I put it into the gear, before i even begin to depress the clutch.
SoMe0nE2tAlK2 is offline   Reply With Quote
Old 12-21-2007, 03:40 PM   #2 (permalink)
bobby2002s2k.
S2K 4 life!!
bobby2002s2k.'s Avatar
I"m use to it, mine does that every now and again. I've ran into no problems. I kinda like it, it assures me that its really in gear.HAHA>
Old 12-21-2007, 05:07 PM   #3 (permalink)
Hi K2,
not abnormal. I feel the same thing in mine all the time. It's just the geartrain hooking up. More a byproduct of having less car around you to insulate whats going on underneath you. Many things about real sports cars are more pronounced compared to your average fare.
drive.....
Old 12-21-2007, 05:29 PM   #4 (permalink)
SoMe0nE2tAlK2
alrighty. Thanks for the quick reply.
Just wanted to make sure it wasn't anything i needed to return while I still got my waranty hehe.
Old 12-21-2007, 06:18 PM   #5 (permalink)
ottokrat
ottokrat's Avatar
I think it's normal; I have it too.
I have found that pulling the shifter firmly toward the driver's side against the stop/rail helps a bit - then again maybe it's just me and maybe it's just 'cause when I do that I go slower into 1st. But I think there may be something to it at least it my car. If I try just to go slow (w/o pulling to the side while moving the shifter forward), I still get a clunk, but if I pull a bit to the side while moving into gear, it usually doesn't.
Others say, and this works for lots of different vehicles, move the shifter into some other gear, then go to 1st; that usually avoids the clunk. (On my truck, after I come to a full stop, I have to go move the shifter briefly into 5th before reverse otherwise I get a big clunk/crunch going into reverse!) (And you don't want to let out the clutch in that other gear - just move the shifter there are come out.)
2006 S2000 Suzuka Blue
San Jose, CA
ottokrat is offline   Reply With Quote
Old 12-21-2007, 07:15 PM   #6 (permalink)
S2000dude
S2000dude's Avatar
I'd say if you're uncertain take it to the dealer and ask them to check it.
Usually they'll bend over backwords for a new customer.
Old 12-22-2007, 11:41 PM   #7 (permalink)
Vezna31
Vezna31's Avatar
Check one thing...be on a level surface without the brakes on and put it into 1st gear slowly. Does the car creep forward a few inches? If so, the clutch is not fully disengaging. I believe this is actually normal in this car because my car did it too. I just had the clutch replaced at 109k and it still does it.
http://www.vezna.com
