Old 12-28-2007, 05:54 PM   #1 (permalink)
grocerystore_ninja
grocerystore_ninja's Avatar
spoon propeller shaft
inlinefour has it for 322 is it worth it
grocerystore_ninja is offline   Reply With Quote
Old 12-28-2007, 06:56 PM   #2 (permalink)
Not if you don't need it.
Old 12-28-2007, 11:02 PM   #3 (permalink)
grocerystore_ninja
is it lighter weight
Old 12-29-2007, 09:48 AM   #4 (permalink)
grocerystore_ninja
bump
Old 12-29-2007, 10:02 AM   #5 (permalink)
I investigated carbon propeller shafts. The problem with our cars is that the propeller shaft is very short and the weight is mostly concentrated on the U joints at each end. So short of making them out of some exotic material which would be prohibitively expensive, the stock one is not too bad.
Old 02-08-2008, 11:11 AM   #6 (permalink)
Rick006
Carbon fiber drive shaft
I do know for a fact if you have the money you can drop the drive shaft weight by at least 2 pounds.
Rick006 is offline   Reply With Quote
