Old 01-17-2008, 01:25 PM   #1 (permalink)
sharptech
valve adjust problem...
So I just got this 01 s2000 great car only ticked really bad so I did the valve adjustment as per specs.. .08 on intake and .11 on exhaust. Thousand miles later ticking really bad again so I pop the valve cover and the intake are .11 and exhaust .12 is the tappet screw backing out? Has anyone had this problem as well? Thanks for any input
sharptech is offline   Reply With Quote
Old 01-17-2008, 01:57 PM   #2 (permalink)
questions, Sharptech.
is the engine modified? and how hard were those 1,000 miles?
Old 01-17-2008, 02:05 PM   #3 (permalink)
sharptech
intake and exhaust...not track miles or anything but I like to have fun.
Old 01-17-2008, 02:44 PM   #4 (permalink)
You need to tighten the lock nut down to spec. I use a crows foot wrench for some of the hard to reach ones.
Old 01-17-2008, 02:58 PM   #5 (permalink)
sharptech
I did. One of them I overtorqued and broke and had to replace.
Old 01-17-2008, 03:22 PM   #6 (permalink)
Having fun.....or bouncing it off the rev limiter often?
Other than the ticking----any performance losses?
Old 01-17-2008, 04:08 PM   #7 (permalink)
sharptech
well come to think ya there was a power loss. I dyno'd 198whp stock then did cai, 63mm exhaust with test pipe, ngk irridiums, and the valve adjustment, Then dyno'd 190whp on the same dyno. And not off the rev limiter but in vtech alot.
Old 01-17-2008, 04:29 PM   #8 (permalink)
I'd reset the valves again.....make sure you've got everything torqued to spec....(look close at tappets themselves),
then check the timing to be safe. Lots of miles on the engine?
jagg.
Old 01-17-2008, 09:36 PM   #9 (permalink)
sharptech
redid valves, felt good for about 20 miles now starting to feel slow again. Only 40k on the motor.
