Old 02-04-2008, 11:28 PM   #1 (permalink)
ronlevine
Pulstar Plugs?
Hot or not?
ANyone use these? http://www.pulstarplug.com/
ronlevine is offline   Reply With Quote
Old 02-05-2008, 06:28 AM   #2 (permalink)
DJJSR
DJJSR's Avatar
$25 each x 4 = $100. They claim $8 per hp, so that $100 should yield 12.5 hp right? I'm not the sharpest tool in the shed, but I seriously doubt it.
Don
Old 02-05-2008, 07:18 AM   #3 (permalink)
I have been running Denso Iridium ik 22's for nearly 100k miles. I don't think there is a magic spark plug on the horizon
Old 02-05-2008, 07:25 AM   #4 (permalink)
bbcricketta
just read this:
now try this:
http://www.ngksparkplugs.com/techinf...000&country=US
2007 berlina black
Old 02-05-2008, 07:56 AM   #5 (permalink)
SXY_S2K
Trqless
SXY_S2K's Avatar
There was an article about this in last months D-Sport Magazine. If I recall, they gave them a rave review and Dyno tested 4 cars, all which showed about 6-10 HP increases... Can't remember the exact numbers tho, I will read the article again when I get home.
www.myspace.com/kesmith3
SXY_S2K is online now   Reply With Quote
Old 02-05-2008, 08:03 AM   #6 (permalink)
bbcricketta
install some and report back.
but, don't be disappointed.
2007 berlina black
Old 02-05-2008, 08:25 AM   #7 (permalink)
Rick006
Pulstar plugs
I did purchase them and will dyno before and after installation.
Rick006 is offline   Reply With Quote
Old 02-05-2008, 06:41 PM   #8 (permalink)
Excellent. Looking forward to your review.
Old 02-05-2008, 07:38 PM   #9 (permalink)
bobby2002s2k.
S2K 4 life!!
bobby2002s2k.'s Avatar
Make sure you buy a brand new set of what plugs you got in now, dyno them new and then put the pluse plugs in and dyno it with them. You probably already know that. Anyways thats how they can claim the increase in hp. Just like every other part that comes with a dyno Most of the time. If you improve everything exept one thing and dyno it, then replace the weak link then dyno it again yeap its goin to show a increase. Example. Your tryin to market cams. So you get a car dyno stock then slap just cams in it and dyno. Not to much gain, if you do intake, exhaust dyno it. Then put the cams in it, its goin to show a much larger gain. This is like i said how they market stuff to show such gains.It not fake numbers its just misdirection of how they got them.
Old 02-05-2008, 09:40 PM   #10 (permalink)
philiam
Feel free to correct me if I'm wrong, but... I think that a spark plug's job is to light the fuel/air mixture and the burn takes it from there. If the heat range and gap are right and the plugs don't oil foul there should be no difference. I use platinum plugs. They keep the gap longer because the center electrode doesn't wear away as quickly. The s2k has a very advanced ignition system. I've never experienced a miss, unless going over the 9k rev limiter. I think this is another slik 50, turbo air intake, or the gadget they use to sell at swap meets that attached to the coil to boost the spark.
philiam is online now   Reply With Quote
Old 02-06-2008, 02:36 AM   #11 (permalink)
There goes Phil again sayin' whut I'm thinkin'.
How a plug can cause the same amount'a air/gas mixture to make more power seems jus' a wee bi' far fetched ta this ol' (with all due respect Phil) tire-kicker.
('Lessen each plug comes with it's own little set a injectors maybe)
But, by all means . . . like Go, I'm lookin' forward to your review. (Quick! Somebody get me a calculator! I think he jus' broke his record for words in a post!)
Be well,
Old 02-15-2008, 10:49 PM   #12 (permalink)
Rick006
There has been a delay in checking the power on the plugs. Will get it posted when I can.
Old 02-18-2008, 06:32 PM   #13 (permalink)
tuna79
tuna79's Avatar
Sounds like the same as a MSD (multiple spark discharge) system. More spark will get you a more efficient fuller burn. Thats assuming it doesn't get too hot and start popping a hole in your piston.
tuna79 is offline   Reply With Quote
Old 07-01-2008, 07:05 PM   #14 (permalink)
kerpal
IF you improve everything, and yet didn't replace the weak link, wouldn't the weak link get worse? I mean, you should try to remove the weak link right? And, when replacing the everything, that means you replace the basics like the spark plugs as well. You think it is wise to use pulse plugs?
kerpal is offline   Reply With Quote
Old 07-01-2008, 08:13 PM   #15 (permalink)
4406pack
cone destroyer
4406pack's Avatar
if these plugs will increase hp, then you should see an increase in mpg as well...you would think....
Old 07-01-2008, 08:58 PM   #16 (permalink)
philiam
Electricity takes the path of least resistance. If the bottom electrodes are all equal gap, they will fire randomly. When one electrode loses a bit of metal, the spark will skip that on but still fire on the others.
