Old 02-10-2008, 09:33 AM   #1 (permalink)
bobby2002s2k.
S2K 4 life!!
bobby2002s2k.'s Avatar
vibration ???
Well i got my competition stage 2 clutch and pro street fly wheel put installed. Clutch grabs really nice. love it. The problem is there is a vibration and something that sounds like a non lubed bearing at around 2g-3g rpm range. It only does it on decel or a constant speed in this range with no load on the engine. When the noise is present i can touch on the clutch and feel it in the petal if i press alittle more to disengage it will stop the noise and vibration. Oh with the install I also put in new bearing throw out and pilot that came with the clutch. I'm thinkin its one of them? But not 2 sure. I'm kickin myself in the a@# bc i should have went and got a oem bearing from Honda. No matter what the trans is comin back out. Maybe if the bearings are bad Competition clutches will cover the install. But I'm goin to have a hard time proving that,LMAO. Anywho all help is appreciated.
Old 02-10-2008, 11:06 PM   #2 (permalink)
seeno
seeno's Avatar
Send a message via MSN to seeno Send a message via Yahoo to seeno
hey, i'm no pro but did u install the clutch?
seeno is offline   Reply With Quote
Old 02-11-2008, 06:02 AM   #3 (permalink)
bobby2002s2k.
S2K 4 life!!
No a good friend of mine that ownes his own shop installed it which i have no question that it was installed correct.
