Old 05-16-2008, 02:46 PM   #1 (permalink)
JDMzimbo
s2k4life
JDMzimbo's Avatar
Unhappy Clutch problem
Hey guys i just got my 2000 s2k about a month ago. just recently though the cluch kept changing between being really easy to push in, to really hard. Yesterday i got in and the cluch felt really stiff, more than usual. It is still stiff and seems to be staying that way. I have no idea what the problem is, so any info would be great. Thanks
Old 05-16-2008, 03:33 PM   #2 (permalink)
J'sS2K
J'sS2K's Avatar
Clutch fluid?
Old 05-16-2008, 04:52 PM   #3 (permalink)
philiam
Possibly air in the line or bad throwout bearing.
Old 05-16-2008, 06:57 PM   #4 (permalink)
mlc
Try looking here. Do a little looking around I am pretty sure you can get pointed in the right direction.
http://www.s2ki.com/forums/index.php...#entry11623289
Post up if you have more questions.
mlc
Old 05-16-2008, 07:00 PM   #5 (permalink)
mlc
It is a My00. You might want to bleed the clutch also. If you need DYI instructions post up.
mlc
Old 05-16-2008, 07:07 PM   #6 (permalink)
PRB2000
PRB2000's Avatar
its the clutch slave cylinder, i just got done replacing mine. master and slave. it was doing the same thing you described.
P R B
Sunday Laxative
PRB2000 is offline   Reply With Quote
Old 05-17-2008, 07:59 AM   #7 (permalink)
JDMzimbo
s2k4life
JDMzimbo's Avatar
Thanks for the help guys, ill give you a shout if I need more help.
Old 05-17-2008, 04:50 PM   #8 (permalink)
bobby2002S2K
bobby2002S2K's Avatar
If your master cylinder is starting to go out it will drip inside your car. Shove yourself down under your steering wheel and slide your finger down the little rode behind you clutch petal. If there is a drop of fluid there its bad or goin bad. Thats what mine did. So like prb2000 i replaced both slave and master cylinder, just good policy.
