Old 05-18-2008, 08:01 AM   #1 (permalink)
padoos1
engine oil capacity ?
how much oil with filter does an 05 s2000 take , i bought this car used and didnt get a manuel with it and i want to do an oil change, also how many miles would you go between oil changes useing synthetic oil ....... thanks in advance
padoos1 is offline   Reply With Quote
Old 05-18-2008, 08:20 AM   #2 (permalink)
The Good Book listz it as 5.1 US quartz both wayz pad (I love answerz like that, don'choo?).
'Bookz're good, but they're jus' a reference, a startin' point.
Drain it. Pudd'in yer 5 quartz. Runn'er up. Let it settle'n season accordin' to yer dipstick.
If I wuz gettin' paid by the hour, I'd jus' dump whut the book sayz. When it'z mine I get fussy. (Don't believe any picturez that the guyz show you.)
Be well,
Old 05-18-2008, 09:03 AM   #3 (permalink)
Grumpy old(er) phart
You got the one without the Mexican who's supposed to do your oil changes? Check in the secret compartment, you may have a manuAl there...you can also get an argument about changing synthetic oil at anywhere from 3000 miles to 7,500 miles..personally, I do it after every meet or 3000 miles, whichever comes first...I also change the transmission fluid (Honda MTF) and Diff (Redline 75w-90) after every other meet or 3000 miles. Oil/lube is cheap, engine parts aren't.
Old 05-18-2008, 10:50 AM   #4 (permalink)
DJJSR
DJJSR's Avatar
For average driving conditions, synthetic oil still remains serviceable beyond 5000 miles. If you're still under warranty, stick to the book. If you make a lot of short trips and don't get the engine up to temperature, you need more frequent changes. If your car is out of tune or you drive in dirty conditions a lot, you also need more frequent changes.
Don
Old 05-18-2008, 12:41 PM   #5 (permalink)
No comment.
Old 05-18-2008, 01:56 PM   #6 (permalink)
sky2k
sky2k's Avatar
yep, 5, and i use a K&N oil filter, a little more $ but they are the best. And i change every 3000
Old 05-18-2008, 04:33 PM   #7 (permalink)
chazdawg35
chazdawg35's Avatar
I use Mobil 1 after it burps usually get 5.5 in there,K&N oil filter is a must.Also using a magnetic drain plug,suppose to be the $H!t.
Old 05-18-2008, 04:43 PM   #8 (permalink)
As I have said previously I use Redline for everything. 10w30 for 12000 miles and change the oil filter every 3000, per Redline's instructions. Diff oil when i feel the clutches and transmission every 6 months.
Old 05-18-2008, 04:48 PM   #9 (permalink)
DJJSR
DJJSR's Avatar
Am I reading this right? You go 12,000 miles between oil changes and you change the transmission oil every 6 months?
Don
