Old 07-13-2008, 04:58 PM   #1 (permalink)
chazdawg35
chazdawg35's Avatar
Fluid Capacities?
Hey Dudes does anyone know how much fluid the stock transmission holds in a AP1. Also what about the rear differential?
Old 07-13-2008, 06:18 PM   #2 (permalink)
batguano
Andiamo Veloce
batguano's Avatar
You can find what you need here Dude.
https://techinfo.honda.com/rjanisis/...20206INDEX.pdf
MY VID
http://s66.photobucket.com/albums/h2...DBR2008Pt1.flv
Nikola Tesla,I salute you.
Old 07-13-2008, 06:41 PM   #3 (permalink)
chazdawg35
chazdawg35's Avatar
Thanks Bat! I was thinking of using Royal Purple what do you think?
Old 07-13-2008, 07:21 PM   #4 (permalink)
Royal Purple is a good product. Expensive, but good.
Old 07-13-2008, 07:41 PM   #5 (permalink)
chazdawg35
chazdawg35's Avatar
I have it in there now with about 4000 miles of use some track time and hard driving. Veneza31 said that I should change them after track time and I figured that it wouldn't hurt or with the miles is it a waste of money?
Old 07-13-2008, 07:57 PM   #6 (permalink)
batguano
Andiamo Veloce
batguano's Avatar
My opinion is that you are paying for color.
I am running Honda MTF in the tranny and Valvolene 75X140 synthetic in my 356 diff. I am pleased with the setup.
MY VID
Old 07-13-2008, 08:39 PM   #7 (permalink)
Personally, I use the Honda MTF as well.
Old 07-13-2008, 08:56 PM   #8 (permalink)
chazdawg35
chazdawg35's Avatar
I seen it on sale at PEP BOYS for $9.99 a quart seemed not that bad.
Old 07-13-2008, 09:39 PM   #9 (permalink)
J'sS2K
J'sS2K's Avatar
AP2 holds about 2.7 quarts. It should be very close to AP1.
Old 07-13-2008, 10:34 PM   #10 (permalink)
That is a very helpful link bat, I think I will make a new thread using that link and sticky it. Thanks for the link.
Old 07-13-2008, 10:47 PM   #11 (permalink)
chazdawg35
chazdawg35's Avatar
So I should be cool to buy 3qts for the transmission and 3qts for the differential
Old 07-13-2008, 10:58 PM   #12 (permalink)
Transmission is only 1.6 quarts for the AP1. I can't believe there would be that much difference between the two models.
Diff is less than a quart.
https://techinfo.honda.com/rjanisis/...202O00252A.pdf
Old 07-13-2008, 11:07 PM   #13 (permalink)
chazdawg35
chazdawg35's Avatar
[quote=gomarlins3;53248]Transmission is only 1.6 quarts for the AP1. I can't believe there would be that much difference between the two models.
https://techinfo.honda.com/rjanisis/...202O00252A.pdf[/QUOT So if I buy 2qts will be cool for the trans and 1qt for the diff.
Old 07-13-2008, 11:10 PM   #14 (permalink)
Yes, you should be fine. That's what I usually go with.
Old 07-13-2008, 11:23 PM   #15 (permalink)
philiam
From what I've read the only recommendations are Honda MTF or a GM variant , don't remember the name. In the diff Honda or Mobil 1 70-90, my choice. Haven't seen any research on Royal Purple.
Pep Boys had RP on sale for $7 this weekend.
Old 07-14-2008, 07:17 AM   #16 (permalink)
batguano
Andiamo Veloce
batguano's Avatar
That GM product is the GM Syncromesh. I've heard good things about that too.
MY VID
Old 07-14-2008, 07:18 AM   #17 (permalink)
batguano
Andiamo Veloce
batguano's Avatar
If you need the full menu for all years, here it is.
https://techinfo.honda.com/rjanisis/...01_OMANUAL.asp
I refer to those links often.
MY VID
Old 07-14-2008, 07:22 AM   #18 (permalink)
batguano
Andiamo Veloce
batguano's Avatar
FWIW, I also add a small quantity of Hyphoid better known as Friction Modifier to the diff. I am running a 356 and it's a little whiney and the additive helps.
I get mine at the Ford dealership.
MY VID
Old 07-14-2008, 09:49 AM   #19 (permalink)
DJJSR
DJJSR's Avatar
My wife gets a little whiney sometimes. I'm headin' for the Ford place.
Don
Old 07-14-2008, 10:42 AM   #20 (permalink)
batguano
Andiamo Veloce
batguano's Avatar
Be careful and don't over medicate. She might get too agreeable and sweet.
MY VID
