I have a bad vibration coming from the rear when accelerating, starts at 64 miles per hour and comes out around 83 miles per hour. Had Honda balance and check tires,( looked ok). Anybody have Ideas or has had this problem, no loud or whining noises.
What yr is the car? Has it been raced? You need to provide more information. It could be a bent wheel, a half shaft, the propeller shaft. If it appears and disappears then something is out of balance and you are feeling a harmonic.
Its an 01, never been raced just turned 81,000. Honda checked for out of round tire and bent rim. nothing there.
Troy |
It could also be the LSD. Check for and looseness in the drive train. Jack up 1 rear wheel (use a jack stand), and release the parking brake. Watch the ujoint on the diff as you gently turn the raised wheel and see if there is any clearance. In my AP1 at 85000, the LSD was done for and the half shaft and propeller shaft cv joints were showing wear. I changed everything. (if the CV joints are bad, buy a new half or propeller shaft, you will save hugh $$ in labor).
