Old 07-25-2008, 11:30 AM   #1 (permalink)
JOECHY
JOECHY's Avatar
heat soak
Can someone explain to me the signs of engine heat soak? I hear the term regularly but I don't fully undestand how to detect it.
Thanks
Old 07-25-2008, 12:27 PM   #2 (permalink)
I believe it is when the engine bogs down when you start from a stop or try to go full throttle from low RPMS. I have never had it happen to me, but then I have had a CAI or boost pretty much from the start of ownership.
Old 07-25-2008, 12:34 PM   #3 (permalink)
Neil
Neil's Avatar
Up here in Canada we see and say things a little different, let me know if any match.........
Heat stroke, feet poke, teeth choke ...............................sorry for the smart ass reply there Joechy, as I just feel in a funny mood !
Neil
Old 07-25-2008, 12:50 PM   #4 (permalink)
J'sS2K
J'sS2K's Avatar
I think it means when the engine produces an excess amount of heat.
Old 07-25-2008, 01:17 PM   #5 (permalink)
Grumpy old(er) phart
If you have one of those snorkel type CAI's made from metal, they generally run near the radiator. Because of the large amount of heat in that area, the CAI absorbs a lot of that heat. Heat + gasoline = very lean mixture. That lean mixture is not as combustible as your normal mixture. The car bogs down on take-off. Mostly noticeable when you're at a stop light and start to take off when the light changes. You'll know it's heat bog because your head will hit the steering wheel before the car decides to richen the mixture a bit to compensate.
Old 07-25-2008, 01:21 PM   #6 (permalink)
tuna79
tuna79's Avatar
Hot air contains less O2 so you'ld be getting a rich condition. Still bog you down but safer than a lean condition.
tuna79 is offline   Reply With Quote
