Rattling noise coming from top tensioner!
hi ppl im in need of some help i just bought an s2k today and traveled 480 miles bak home with it, iv noticed there seems to me a rattling noise coming from the engine ! and noticed the top tensioner has very slight movement on idle ! im also feeling a rummble/groan coming from the clutch pedal when after acceloration ! the car is a 1999 model
How many miles are on it? 1999? Where are you?
Don |
Banned
You might want to go into more detail about the "rattling noise." Where is it coming from or what is it near? And what do you mean about the "rumble/groan" after acceleration?
noise is coming from around the top pulley area just on idle ,i can see the top pulley beside the altenator has movement on idle ! im basically getting vibration coming thre the clutch pedal when coming off power,im located in edinburgh, scotland/the car is on 53000
Sounds like the bearing may be worn in the tensioner. You should probably get that fixed asap before you lose the belt.
The issue with the clutch may be "clutch buzz", a problem that I've heard is not uncommon in the early AP1's. Do a search in these forums using the term "clutch buzz" (in quotes) and you'll see more info about it.
Don |
