Old 08-01-2008, 12:29 PM   #1 (permalink)
rusyus
Valve Cover AP1 vs AP2
Hi,
I'm new here.
Just bought an s2000 that needs some work.
Does anybody know if Valve Cover is different on AP1 and AP2?
I know part # is different, but i need more info.
I've seen a cover sold on e-bay that says 00-05, and they say that ap1 differs from ap2 by PCV valve that can be changed.
Can anyone confirm this?
Thanks a lot
rusyus is offline   Reply With Quote
Old 08-01-2008, 12:44 PM   #2 (permalink)
dezignpro04
All MOTOR S2K
dezignpro04's Avatar
AP2 started in 2004. So if it said that the VC is the same from 00-05 that to me would contradict the AP1 being different from the AP2.
Maybe someone else can chime in..
Old 08-01-2008, 01:56 PM   #3 (permalink)
rusyus
Yes. That is true, but actually from 2006 and up there is only 1 sensor on the cover instead of 2 like on 00-05, so for AP2 there are 2 different types. I still wonder if anypne knows about AP1 vs AP2 (04-05).
Thank you.
