Old 08-02-2008, 11:43 AM   #1 (permalink)
AeroS2000
AeroS2000's Avatar
S2K with Redline oil USERS come help!
if you use Redline motor oil, Does it burn quick? im using mobil 1 and its burning like no tomorrow. i herd Amsoil is good and doesnt burn alot but their dealers are so far away from here. Is Redline oil as good as amsoil???
S2000 MY Rice Rocket
AeroS2000 is offline   Reply With Quote
Old 08-02-2008, 12:08 PM   #2 (permalink)
J'sS2K
J'sS2K's Avatar
What do you mean burn? If it means oil consumption, you might have something else going on.
Old 08-02-2008, 12:14 PM   #3 (permalink)
AeroS2000
AeroS2000's Avatar
yup consumption.
Old 08-02-2008, 12:17 PM   #4 (permalink)
will williams
just havin' fun
will williams's Avatar
I have used Mobil 1 for 4 years in my S2K with no oil consumption. Any car I have ever had that used more then a quart between oil changes had internal engine problems. Better check it out before your engine checks out.
will williams is offline   Reply With Quote
Old 08-02-2008, 12:22 PM   #5 (permalink)
AeroS2000
AeroS2000's Avatar
allright then. gona try to switch to Redline( my oil is 3K old anyways) if its still burning then i guess its the engine
Old 08-02-2008, 01:40 PM   #6 (permalink)
johnmcs1
I've been using mobil 1 and find no problems. Very rarely have to add in any between servicing. What are you using 10W 40? 5W 30? etc
johnmcs1 is offline   Reply With Quote
Old 08-02-2008, 01:55 PM   #7 (permalink)
D1sclaimer
Mustang Killer
D1sclaimer's Avatar
Do you have an AP1?
AP1s are notorious for burning oil. If you take hard right hand turns, oil will leak out from the pcv valve into your intake. They fixed it with the AP2. Hence this is why the pcv is different in AP2s.
BTW I use Mobil 1 and have lost a 1/4 quart in a few months.
Old 08-02-2008, 02:52 PM   #8 (permalink)
AeroS2000
AeroS2000's Avatar
Originally Posted by D1sclaimer View Post
Do you have an AP1?
shit! are u serious? i got an AP1. mobil 1 sucks for me. gona try different brand.
Old 08-02-2008, 02:55 PM   #9 (permalink)
AeroS2000
AeroS2000's Avatar
btw already gone thru 4 bottles before this next oil change
Old 08-02-2008, 03:10 PM   #10 (permalink)
J'sS2K
J'sS2K's Avatar
You have a serious problem bro! You should pay a visit to your local Honda dealer.
Old 08-02-2008, 03:44 PM   #11 (permalink)
D1sclaimer
Mustang Killer
D1sclaimer's Avatar
Yep. Thats about 1 bottle short of a full oil change. Way too much oil being burned up.
Old 08-02-2008, 07:42 PM   #12 (permalink)
DJJSR
DJJSR's Avatar
I think you better do a compression or leak-down test. Switching oils is not going to fix your problem.
Don
Old 08-02-2008, 08:00 PM   #13 (permalink)
satisaii
Send a message via AIM to satisaii
Two things to check:
PCV system not functioning correctly. It is cheap to replace that valve, just do it. You can even pull it off and check it by blowing into it.
You may be using a very light weight oil. A 10 or 20 weight oil designed more for racing applications might have some control issues on a higher mileage car. Especially in a hotter climate. I almost did this. I bought some oil for the track car and figured I would use it in the S2000. Lucky for me, I caught this mistake before I even received the oil (Redline) and ordered some more just for the S. I will be doing the change next week, so I don't have any feedback on the oil.
satisaii is offline   Reply With Quote
Old 08-02-2008, 08:42 PM   #14 (permalink)
philiam
When you drive a high performance car hard, some oil consumption is to be expected. If you use less than a quart in 1000 miles, not a big deal. It means that hard working parts are getting lubed. Especially when you hit Vtec.
I use Mobil 1 and use less than 1 quart between changes. The way the engine was broken in will have an effect on consumption as well. Also, check that none of your seals is leaking.
Old 08-02-2008, 09:32 PM   #15 (permalink)
chazdawg35
chazdawg35's Avatar
Hey Dudes MOBIL1 for me and some burning but not that bad 1/2QT at most between oil change's
Old 08-04-2008, 02:13 PM   #16 (permalink)
AeroS2000
AeroS2000's Avatar
ok... ived got this car about 2 months ago. it just hit the 60K miles mark. ived drove it for about 3k miles already and had experience oil burning like never seen b4. ived just switch to Redline on Saturday. im gona see if it still burns the same as mobil 1
Old 08-04-2008, 03:30 PM   #17 (permalink)
S2K AP2
S2K AP2's Avatar
You should be careful. If you haven't taken the S2K into a dealership to get it checked, it'd be best if you did now.
S2K AP2 is offline   Reply With Quote
