Old 03-12-2009, 03:47 AM   #1 (permalink)
rossos
Oil...
Whats the best for the S2000?? having an oil change monday... 0-40??
rossos is offline   Reply With Quote
Old 03-12-2009, 05:38 AM   #2 (permalink)
mlc
mlc's Avatar
Ahhh. The eternal question. This has been asked more times then then the national debt. Here is a good place to start http://www.s2ki.com/forums/index.php...#entry12038273. Just a lot of good reading.
You are going to get many different opinions on oil. Today most oils will do just fine. A couple of basicis to keep in mind. This car has a tendency to burn some oil. Check it regularly,like once a week until you know how much oil it uses(the more you VTEC the more it will use). And change it at normal intervals and you shouldn't have any problems.
Good luck.
Kevin
Now I can just sit back and watch
