Old 04-28-2009, 07:31 PM   #1 (permalink)
Spartanic
Thumbs up S2000 DIY repair info in here, check it out
I wasn't too sure which category to put these DIY repair info in so I bunched them together into one post. Let me know if you guys see any errors. Writeups include F20C engine removal and installation, cooling system, lubrication, wheel bearings, etc etc.
The list of completed write ups:
S2000 Brake System
S2000 Cabin AirFilter
S2000 Cam Chain
S2000 F20C camshafts.
S2000 F20C camshaft gear removal and installation.
S2000 Clutch
S2000 Interior Console
S2000 Cooling System
S2000 F20C Crank Pulley
S2000 F20C crankshaft.
S2000 F20C Cylinder Head
S2000 F20C cylinder head inspection.
S2000 F20c Engine Install
S2000 F20c Engine Removal
S2000 interior dash removal. Garage411.com
S2000 Exhaust System
S2000 F20C flywheel removal and installation.
S2000 Horn
S2000 Hub Assembly
S2000 Ignition
S2000 Immobilizer
S2000 Lubrication system
S2000 Interior Seats
S2000 rocker arms. Garage411.com
S2000 Rear Suspension
S2000 Trunk
S2000 Universal Joints
S2000 F20C Valve Clearance
S2000 VTEC solenoid test
S2000 Wheel Alignment
S2000 Wheel Bearing
Critiques welcomed. More updates coming soon...
Spartanic is offline   Reply With Quote
Old 04-28-2009, 08:00 PM   #2 (permalink)
s2k01
s2k01's Avatar
Can i get a radiator install/removal? Or is it to easy lol
Old 04-28-2009, 08:01 PM   #3 (permalink)
RL1924
RL1924's Avatar
This is what I call a first post!
RL1924 is online now   Reply With Quote
Old 04-28-2009, 08:02 PM   #4 (permalink)
RL1924
RL1924's Avatar
Also check out here
http://www.s2katlanta.com/forum/showthread.php?t=909
Old 04-28-2009, 08:09 PM   #5 (permalink)
redS2k06
redS2k06's Avatar
I agree! welcome aboard
"ya this car rocks just being stock ......hey that aint a bad quote " TheSoundMan21
redS2k06 is offline   Reply With Quote
Old 04-29-2009, 07:17 AM   #6 (permalink)
playingmilitary
poor coasty
playingmilitary's Avatar
great post thank a bunch
"this is great its a miata with a set of balls" my mom
playingmilitary is offline   Reply With Quote
Old 06-07-2009, 01:52 PM   #7 (permalink)
Spartanic
The radiator shouldn't be too hard to remove. All it really is is removing the upper and lower hose and then a few bolts here and there and it'll come loose. Of course drain the coolant first.
Old 06-07-2009, 02:54 PM   #8 (permalink)
J'sS2K
J'sS2K's Avatar
We should sticky this.
www.getgopod.com
Old 06-07-2009, 02:56 PM   #9 (permalink)
J'sS2K
J'sS2K's Avatar
this is one kick ass exhaust!
(this pix is from the Exhaust System DIY)
www.getgopod.com
Old 06-08-2009, 04:08 PM   #10 (permalink)
Spartanic
Its an ASM unit that you probably wont be able to find here in the states.
Old 07-08-2009, 02:27 PM   #11 (permalink)
franke
franke's Avatar
do u have any info on removing the tranny???
franke is offline   Reply With Quote
Old 07-08-2009, 02:48 PM   #12 (permalink)
RL1924
RL1924's Avatar
Could be wrong.. but I know me not knowing how to take off the tranny a DIY would not be the best way to attempt and tackle that.. I could be wrong though
Old 07-08-2009, 06:08 PM   #13 (permalink)
mlc
mlc's Avatar
If you are up for it here you go http://forums.s2kca.com/showthread.php?t=14201
Kevin
Old 07-08-2009, 08:24 PM   #14 (permalink)
RL1924
RL1924's Avatar
Kevin
Ekk... too much risk for me
Old 07-10-2009, 11:46 AM   #15 (permalink)
franke
franke's Avatar
Thumbs up
Kevin
thanks
Old 07-12-2009, 09:45 AM   #16 (permalink)
Spartanic
I could probably brew something up. Be on the lookout soon...
Old 07-12-2009, 10:14 AM   #17 (permalink)
playingmilitary
poor coasty
in the clutch
im sure that the clutch diy post has the trans in it you do have to move it to get to the clutch.
bearings, clutch, crank, diy, engines, f20c, forum, front, head, honda, horn, install, pulley, removal, repair, replace, s2000, wheel
