Old 08-06-2009, 04:16 PM   #1 (permalink)
matrad
Lightbulb f20 swapped to f22 questions
im new to honda in general and i enjoy the ease of working on them.
im normally working on a KA24 nissan or 4g63 mitsu.
anyways me and my bro are repairing the AP1 f20 s2k we purchased
come to find out cylinder 3 had bad compression due to side walls scarred up(bad rings or FOD). so local guy sells me block for f22. this is what i know
bore between the 2 is the same. only difference is the stroke. so my guess would be using same pistons in the f22 as the f20 but different crank and rods.
This is what i need to know
1. can i swap the internals(crank rods pistons) from f20 to f22?
2. if not what is the process of boring the f20 since is has FRM wall lining?
3. what is compatible between the 2 engines? because they seem almost identical?
any professional help would be greatly appreciated
matrad is offline   Reply With Quote
Old 08-06-2009, 04:32 PM   #2 (permalink)
turbosix
they definitely have different part numbers..
turbosix.net
Old 08-06-2009, 04:36 PM   #3 (permalink)
matrad
ya i checked that already
i would like to know if it would work. im gonna start measuring everything up.
maybe someone can tell me what will and will not work
Old 08-06-2009, 08:25 PM   #4 (permalink)
MutantCheese
The Cheeziest!
MutantCheese's Avatar
My friend has a f20 block for sale $300 (New Orleans) if the f22 block doesn't pan out.
2008 S2000 New Formula Red (K&N FIPK; Berk Ceramic coated SS headers; Berk SS HFC; Tanabe Concept G SS exhaust; Hondata toda Reflash; OEM front lip); Eibach Prokit lowering springs
2006 Civic Si NBP w/hfp kit (Too many mods to list here)
2008 CR-V EX-L w/Nav
Visit: www.GNOunderground.com
Old 08-07-2009, 03:09 PM   #5 (permalink)
matrad
what is all included with this?
Old 08-07-2009, 04:08 PM   #6 (permalink)
MutantCheese
The Cheeziest!
PM sent
Old 08-07-2009, 06:22 PM   #7 (permalink)
matrad
i think im gonna try the f22 block, whats the worst that can happen? things dont fit right? the way i see it the f22 motor only has different crank+pistons+rods because they lowered the compression and increased the stroke. if you look at this website towards the bottom it shows they make the same kit for both blocks.
http://www.nolimitmotorsport.com/bri.../f20cf22c.html
this is why im convinced that f20 internals will fit in a f22 block.
if anyone has a reason why these 2 should not wed please speak now or forever hold your peace.
Old 08-07-2009, 06:30 PM   #8 (permalink)
matrad
I will have leftover parts after this for sale
22, crank, difference, engine, engines, f20, f20c, f22, f22a, f22b, honda, motors, oem, s2000, swap
