Old 09-07-2009, 03:50 PM   #1 (permalink)
will williams
just havin' fun
will williams's Avatar
Got rid of the dreaded exhaust drone!!!
I love the sound of my Invidia exhaust. However, I hated the drone that seamed to go along with it. After several tries nothing really helped. Now the engineer in me had to figure out a way to solve this. After a lot of thinking about what could cause the drone I tried something different, its not the exhaust, its the car. With that in mind I purchased a sound deading material call "Spectrum" by a company named "SecondSkin". I removed the exhaust and striped down the trunk. Applied severial thick coats over the entire reachable surfaces. It can be sprayed however I chose to paint it on with several paint brushes. It really works.
will williams is offline   Reply With Quote
Old 09-07-2009, 04:59 PM   #2 (permalink)
That's a clever solution to a very annoying exhaust. How high a temp can that coating stand?
Old 09-07-2009, 06:30 PM   #3 (permalink)
will williams
just havin' fun
according to the mfg. it is not designed as a heat shield. I coated the area starting just in front of the resonator. I did not coat the area near the cat.
Old 09-09-2009, 02:18 AM   #4 (permalink)
HondamakesS2000s
HondamakesS2000s's Avatar
doesnt the mfg give a specific heat tolerance or at least a range? if not, thats a little iffy. iffy's a word, i can use it. i would think you want the stuff to withstand at least 500 deg F just to be safe. (500 only if no where near the cat)
HondamakesS2000s is offline   Reply With Quote
Old 09-12-2009, 01:24 AM   #5 (permalink)
zpeed
Noisy Fire Ball here I come.. Have you fire extinguisher on board?
'06 NFR
zpeed is offline   Reply With Quote
Old 09-12-2009, 02:37 AM   #6 (permalink)
The only problem is that the rest of the world has to listen to that obscenely loud exhaust. And I am quite certain it's power gains are small or non existent.
drone, exhaust, honda, invidia, range, resonator, s2000, solution, solve
« Cams | Power Gain? »
