Old 09-13-2009, 05:57 PM   #1 (permalink)
too many
Wink clutch & rain leak
My clutch pedal goes halfway down before it engages the clutch. I thought my clutch was going out. But I checked my clutch fluid and noticed with the exception of a drop or two the resovoir was empty. I put some fluid in the resovoir but the pedal still goes halfway down before engaging. Should I bleed the clutch if so how?
Second question. While traveling in a thunderstorm recently, my top was leaking on the rubber seal on driver's side. Water was coming in the rubber where the two pieces come together. Any suggestions on what to do?
too many is offline   Reply With Quote
Old 09-13-2009, 06:10 PM   #2 (permalink)
dingleberries
Intermediate Member
dingleberries's Avatar
prob #1 check this out
http://s2000.com/forums/engine-tech-...ng-issues.html
might help in diagnosing or this
http://www.s2ki.com/forums/index.php...&#entry7253853
prob #2
might need to switch to hardtop strikers (hardtopguy.com) if its a leak between where the strikers meet on pass side i had this problem and it was fixed with new strikers
****rain, rain go away so i can drop the top today****
Cheeeeeseee
dident we put u in a dumpster once... I got out
dingleberries is offline   Reply With Quote
Old 09-13-2009, 06:39 PM   #3 (permalink)
Of coarse you need to bleed the clutch fluid. And you probably need to replace the 2 rubber parts. They wear due to getting in and out of the car we humans tend to brush against them.
desmo4 is online now   Reply With Quote
Old 09-13-2009, 06:59 PM   #4 (permalink)
Jim21680
too many, have you heard of the wonderful shin-etsu grease? Strange name, but apparently it's good to use it on all the rubber seals in the car. Might solve the leak problem...maybe. What year is your car?
Jim21680 is online now   Reply With Quote
Old 09-13-2009, 07:12 PM   #5 (permalink)
If you put grease on those parts, you will get get grease on the window and on yourself when entering and exiting the car. It is not practical. It is better I think to spend $50 every 80k miles on new rubber parts.
Old 09-13-2009, 08:26 PM   #6 (permalink)
philiam
It's made for the rubber. I don't get grease anywhere but where it belongs. Just follow directions.
Old 09-13-2009, 08:40 PM   #7 (permalink)
Jim21680
I have had a problem of the grease constantly being on my window edges, but other than that, it's pretty clean stuff...just use it sparingly.
Old 09-13-2009, 10:26 PM   #8 (permalink)
Vezna31
Vezna31's Avatar
Slave cylinder might need to be replaced. My clutch stuck to the floor in the middle of a track day when I realized my fluid had never been changed.
http://www.vezna.com
Old 09-14-2009, 07:06 AM   #9 (permalink)
too many
Thanks for the info! That's why whenever I have a problem with my s2k I check with you guys.
Old 09-14-2009, 07:07 AM   #10 (permalink)
too many
...oh, I have an '03 s2k.
honda, leak, rain, s2000
