Old 03-11-2006, 07:19 PM   #1 (permalink)
Anonymous
Guest
Posts: n/a
Replacing the back window?
Can I upgrade my crappy plastic back window with the updated glass window of the newer modles?
Old 11-14-2006, 12:42 PM   #2 (permalink)
import2nr
I dont believe that's possible because the plastic window zips in to the top. you would probably have to buy a top with the glass window.
import2nr is offline   Reply With Quote
Old 11-15-2006, 12:57 PM   #3 (permalink)
Halo
Halo's Avatar
Forums -> Installed '02 Glass Top on '00 Frame - Instructions w/ Pictures!
Old 12-07-2006, 08:53 AM   #4 (permalink)
sregalia
i live in san diego and own a 2000 S2K; i've had to replace the vinyl rear window 3 times over the years and at $500/pop, i'm unhappy! i was told that the soft-top replacement w/glass will not fit the 2000 year car because of the way the top folds. so i'm stuck with the vinyl and am about to replace it, yet again; any suggestions on how to keep the damn thing from looking like a garbage can liner? i've tried several products, i wash by hand, i even keep it covered. the whole thing's making me very sad!
sregalia is offline   Reply With Quote
Old 12-07-2006, 10:37 AM   #5 (permalink)
When you put the top down, do you put a bumper in with the window?
Old 12-07-2006, 01:58 PM   #6 (permalink)
sregalia
no. first time i've heard of that. how does that help? also, what's good to use on the plastic headlight covers if they're beginning to fog over? i've tried "glass," doesn't do a thing. should i replace them? thank you for your response.
Old 12-07-2006, 09:54 PM   #7 (permalink)
When clear plastic starts to discolor, gettin' to look like the lens itself is sufferin' from a 3 pack-a-day habit, it's usually the plastic aging n' breakin' down into the chemicals from which it came, leachin' out some, leavin' behind the brownish remains: replacement time.
But if it's just surface abrasion that's givin' it a hazy look, somethin' like Meguirs r' one of the other polish/wax combinations n' some elbow grease can bring the surface back to pretty much like-new condition.
Old 12-07-2006, 10:21 PM   #8 (permalink)
sregalia
thanks for the advice. i've tried the meguirs; showed a small improvement. it is 6 years old, i guess it's time to replace. on another note, i found detailed instructions on how to modify an '02-'03 soft top w/glass to fit the '00 car. any advice on whether it's a viable option?
Old 12-08-2006, 05:22 AM   #9 (permalink)
Did you try a buffin' machine with the Meguirs? I preach elbow grease, but sometimes you jus' godda plug things in.
I couldn't say on the top question, but if the source of that info on the top was Halo's post, you can take it to the bank.
Be well n' keep us posted.
Old 12-08-2006, 03:12 PM   #10 (permalink)
sregalia
i don't know who it is but here is the site. the instructions are intricate and well thought out. please let me know what you think. thank you. stephenie in san diego.
http://www.s2000.org/mods/top/s2k_gl...uctions_v2.pdf
Old 12-08-2006, 07:15 PM   #11 (permalink)
HELL_ON_WHEELS
HELL_ON_WHEELS's Avatar
try using PlastX on your headlghts works great for me! I live in San Diego also and never had to replace my rear window.
The guy I bought it from never took care of the car he left the top down ufor over a year before I got it from him!
the car was really mistreated but slowly by surely I'm bring her back to the way she was.
"Drive it like you stole it"
Old 12-14-2006, 10:09 PM   #12 (permalink)
slowf20c
I'd recommend you to buy a 00-01 glass window convertible instead of buying another crappy plastic window. Check on ebay, it is around $800. Or just get a hard top.
slowf20c is offline   Reply With Quote
Old 12-18-2006, 10:48 PM   #13 (permalink)
MattG
It is possible to fit a new top that contains a glass rear window. As far as I know the whole top needs replacing, not just the window part.
Then again if you never put your roof up ...
2000, back, buy, car, glass, honda, plastic, rear, replace, replacing, roof, s2000, s2k, soft, top, window
« Power Outlet | HOOD »
Replacing the Hid headlight? leo520 Exterior / Detailing / Body Work 2 05-22-2008 09:51 PM
Replacing the Parking Light joel37027 Interior / Audio / Electronics 1 11-09-2007 01:16 PM
Replacing turn signal side marker lights mgm Exterior / Detailing / Body Work 6 07-03-2007 08:12 PM
Removing Back Window (plastic) smalls777 All Other Honda S2000 Related Discussions 0 01-16-2006 01:23 PM
S2k back window SinCity-S2K All Other Honda S2000 Related Discussions 4 01-01-2005 04:44 PM
