Replacement Top and rear window
I just picked up a 2001 s2000 and the top is an old hag with the rear window missing. My searches have lead me to Ebay to purchase the top, but who will I go to for the install? How much will bringing my s2000 to the Honda dealer set me back? How hard is the top to install? I actually have a brand new rear plast window so I only need to purchase the top and have both installed. Any advice would be great, I need to get this top up before the Arizona sun dries me out or my valuables get stolen.
I actually have my s2000 completly stripped bare right now because im customizing it, & if you wanted to install the top yourself it shouldn't cause too much of a problem. You should only need to remove a few panels & everything behind the seats (but make sure you make a note of how everything went) & then take out the bolts on the sides holding the top in, & i believe there are some clips too, & pop it out. then just reverse the process.
Where did you get the new plastic window? Can a glass one be placed in?
| 2001, 2006, honda, indow, rear, replace, replaced, replacement, replacing, s2000, soft, tear, top, tops, window |
| Rear window | Snafu4286 | Exterior / Detailing / Body Work | 20 | 04-17-2009 03:32 PM |
| Hard top replacement for 01 S2k | MRK01S2000 | Exterior / Detailing / Body Work | 1 | 03-18-2007 05:23 AM |
| Plastic Rear Window | S2KOOL | Exterior / Detailing / Body Work | 5 | 02-12-2007 12:47 PM |
| Need some help for the rear window | Anonymous | Exterior / Detailing / Body Work | 12 | 06-06-2005 12:30 AM |
| Replacement of my soft top | El Animali | All Other Honda S2000 Related Discussions | 2 | 05-24-2003 06:34 AM |
