Old 11-10-2006, 01:34 PM   #1 (permalink)
marypiercee
More Miles Out of Your Car
Hai,
Getting More Miles Out of Your Car:
The following are some tips that will help you to get more miles out of your vehicle.
First, consider, does your vehicle actually have the ability to run many miles without incurring costly repairs? Find out by visiting a public library to consult the frequency-of-repair information in the April magazine issue of Consumer Reports. If your vehicle has a poor repair history, consider buying a vehicle that has better ratings and fuel efficiency.
If you want to extend the life of your vehicle, at the beginning of each month, have the engine oil level checked to make certain that it is at the full-level mark on the dipstick. Buying two quarts of oil that are on sale and keeping it in the trunk, will enable you to avoid getting stuck paying three times what the oil should cost. Be certain to only use the type of oil and other fluids as specified in the vehicle owner's manual.
Tire Pressure and Fluids:
Every three months (more often, however, if specified by your vehicle owner's manual) and prior to leaving for and upon returning from a trip, check (or have a service station attendant check) the tire pressure and the other fluids that include:
* Transmission fluid
* Brake fluid
* Power steering fluid
* Radiator coolant (check the clear plastic bottle)
* Windshield washer fluid
Why is it important to keep the fluids at their full-level marks? The fluids lubricate moving parts to reduce fiction, heat, and wear. Therefore, they are the single most important factor for extending the life of a vehicle.
marypiercee is offline   Reply With Quote
Old 11-10-2006, 03:17 PM   #2 (permalink)
Always good advice.
I would also advise those of us in really cold weather areas to replace your wiper fluid with winter fluid.
Old 11-13-2006, 10:03 AM   #3 (permalink)
Turbojunkie
Send a message via AIM to Turbojunkie Send a message via Yahoo to Turbojunkie
most windshield washer fluid is alcohol base and it has a hard time freezing unless your -35* below 0
Turbojunkie is offline   Reply With Quote
brakes, fluid, frequency, locate, miles, power, repair, s2000, steering
01 stewie with 70k miles Estukay Off-Topic 10 03-14-2007 04:17 PM
2,400 miles and my first dent! UGA Dawg All Other Honda S2000 Related Discussions 4 07-25-2005 12:54 PM
