Old 01-16-2004, 08:24 AM   #1 (permalink)
Anonymous
Guest
Posts: n/a
Need some help for the rear window
Hi everyone. I just got a 2nd hand S2000 and love it so much. The only problem is that plastic rear window, which is a bit "milky". What is the best thing to do to return it to clear?
Old 01-16-2004, 08:44 AM   #2 (permalink)
Administrator
Re: Need some help for the rear window
I suggest to use specific wax for plastic then ur window will be cleared like the 1st day...
Administrator is offline   Reply With Quote
Old 01-16-2004, 03:05 PM   #3 (permalink)
MattG
I think you mean a plastic polish (not wax).
I suggest using either Meguire's or Plexus brands.
M@
Old 01-23-2004, 07:45 PM   #4 (permalink)
nvrquit4
Send a message via AIM to nvrquit4
I've heard great things about Plexus. Haven't used personally. Couldn't find it at the local store. I did use some Blue Coral and it worked just fine IMO.
Once you clean it you can tint the rear window BTW. I learned about doing that at last years Florida Super Meet...coming first week in April BTW. Check out s2ki.com, Regional communities, then Florida forum for more details.
Simply bought some static tint from Home Depot. My wife cut it and put it on the outside of the window. I only use 100% cotton towels to wash it and it looks great. Probably been on there about 8-10 months now.
First Coast S2000 - One of the "Founding Three" NE Florida's S2000 Club
nvrquit4 is offline   Reply With Quote
Old 02-02-2004, 02:01 PM   #5 (permalink)
DaveU
I tried Meguire's & Plexus, but they seem to require frequent applications to look good.
For the last year and a half I been using a plastic polish/scratch remover. Don't know the brand but it's been working great and I re-treat every few months instead of weeks.
I also keep the car garaged or shaded as much as I can.
Dave
DaveU is offline   Reply With Quote
Old 02-03-2004, 02:15 AM   #6 (permalink)
dohcrwd
Send a message via AIM to dohcrwd Send a message via MSN to dohcrwd Send a message via Yahoo to dohcrwd
my advice is "GET USED TO IT"
WELL SAVE UP FOR HARDTOP.......
GOOD LUCK AND DRIVE SAFE
They said is the V8 that should fear but its the VTEC doing all the smoking here
dohcrwd is offline   Reply With Quote
Old 02-10-2004, 02:47 PM   #7 (permalink)
Anonymous
Guest
Posts: n/a
Window Plight
I finally got me dealer to warranty my 2001 rear window. The question now is should I get some type of pad or mat to put in the boot to protect it from the abrasion that ruined the first one?
Thanks,
JM
Old 02-28-2004, 08:41 PM   #8 (permalink)
Anonymous
Guest
Posts: n/a
When you fold your roof down, the rear plastic window folds in and rubs on the plastic well behind the seats. This causes the middle area of the window to scratch up and look milky.
Once you have cleaned this up with plastic polish I highly recommend buying a MUZ ROOF WELL MAT. This sits in the roof well area and is made so that it does not scratch the plastic rear window.
http://www.prestigeautoaccessories.com.
M@
Old 01-21-2005, 10:51 AM   #9 (permalink)
smalls777
smalls777's Avatar
Send a message via AIM to smalls777
i bought this stuff called novus to remove scratches from my apple ibook. it works great on the rear window too. the number to find someoine who sells it is (800) 548-6872. it comes in many flavors, I use NO.2.
smalls777 is offline   Reply With Quote
Old 01-21-2005, 01:17 PM   #10 (permalink)
gstate
I second the use of novus (the no.2 along with the novus cleaner/polish spray)
gstate is offline   Reply With Quote
Old 04-19-2005, 10:48 PM   #11 (permalink)
5plusjuan
Send a message via AIM to 5plusjuan
I ordered mine today. I'll let you know how it turns out;ill post pics too.
5plusjuan is offline   Reply With Quote
Old 05-03-2005, 07:51 PM   #12 (permalink)
Anonymous
Guest
Posts: n/a
I talked to a guy who owns a convertible shop here in FL. He says that the waxes and polishes work, but only if the discoloration is at the surface level. If the rear window is badly discolored, get up close to it and see if you can tell if it is in between the layers. Apparently the rear window is just a bunch of thin plastic layers that are glued together. The "Milky" color is the adhesive reacting to sunlight / folding of the top. The only way to truely remedy this is to find a totaled 2002-2005 and hock the frame and rag top off of it. This will give you a glass rear window.
Old 06-06-2005, 12:30 AM   #13 (permalink)
MattG
Not all discoloration is due to scratching. Yes the plastic over the years can tend to go yellow due to UV light exposure.
303 Protectant is useful against UV - think of it as sunscreen for your plastic. It is available most commonly at boating stores.
Once you have your window looking good, apply a bit of 303 every few weeks to help keep it that way.
303, clean, cleaning, discoloration, mat, milky, plastic, plexus, polish, rear, roof, s2000, windo, window, yellow
Rear window Snafu4286 Exterior / Detailing / Body Work 20 04-17-2009 03:32 PM
Plastic Rear Window S2KOOL Exterior / Detailing / Body Work 5 02-12-2007 12:47 PM
Rear glass Window S2000GR All Other Honda S2000 Related Discussions 1 06-19-2006 10:16 AM
plastic rear window m5spiess All Other Honda S2000 Related Discussions 5 01-23-2006 12:08 AM
