Write Or Wrong
I 've done it before to past vehicles, but not in the last....10 yrs.
Is it safe to power wash the engine and engine compartment of little stewie ? As always your comments Appricated...............Neil |
Grumpy old(er) phart
You can but you have to stay away from the electrics...(no fuse box, no alternator, no relays, etc)....I'd also buy a can of WD-40 so you can dry the over sprayed water off the electrics that you didn't avoid (and I'd also change Write to Right unless you mean as in write a message like I'm doing now)
NOTICE: Due to Presidential Executive Orders, the National Security Agency may have read this email without warning, warrant, or notice. They may do this without any judicial or legislative oversight. You have no recourse nor protection save to use Pig-Latin for all your messages. "The BS stops when the green flag drops". In memory of David Weber - Malvern Racing |
Spellings correct, thanks kg. Just a little twist
Yes, you can. When I washed mine, I covered the electronical components with plastic wrap, the kind you use in the kitten. Hey, it worked!
Substitute Shinigami
#6 (permalink) | |
Trqless
My kitten doesn't prefer plastic wrap, she's a Paper Towel kinda gal-
![]() Race time. Got to be serious, not stylish. ![]() www.myspace.com/kesmith3 |
#9 (permalink) | |
All MOTOR S2K
You know I just didn't want to blast the engine and not be able to drive for two days .
#11 (permalink) | |
All MOTOR S2K
![]() You will be fine. Just cover your electronics and stay away from the the belt & blower/fan motors.
Thanks Guys....
