Best place for Stainless Steel Hoses?
I dont want the slip coverings. I am looking for the acutally hoses. I have searched and can not find any definite full kit for the S. All the hoses will be redone, so if anyone knows a webiste that sells a variety of different sizes (so I can order all from one place) please let me know.
Thanks |
Don |
ok, maybe I should have been more specific. Thank you though DJJSR, I am referring to ALL Vac/fuel/Radiator hoses.
You can get nice Sampco silicon radiator hoses and intake pipe from King Motorsports. The vacuum hoses and small water hoses are probably only available from the dealer. I would recommend www.hondaautomotiveparts.com
All MOTOR S2K
like my sig...
#6 (permalink) | |
Oh I wish I could see your sig here at work. I will check when I get home though. I already have the braided slip covers on the hoses, but want the REAL thing instead. |
All MOTOR S2K
Mine are steel braided.
You can't put stainless radiator hoses on. They would crack as the engine moves during acc and decel. Same for many of the smaller hoses, they need to be flexible. I have had my car since 99 and only changed the radiator and air intake hoses. None of the others required changing.
I dont know why youd want real lines vs the cover? I also dont see why desmo thinks they would "crack"
#10 (permalink) | |
I see the pics now, and yes that is what I want...where did you order them from if ya dont mind me askin?
Cause I dont want the fake covers...that is as simple as I can put it. |
