Old 08-05-2008, 01:40 PM   #1 (permalink)
s2jz
What kind of bulb is the orange parking light?
both my bulbs blew out a few weeks ago, i need to replace them. anyone know what the model number is for the orange bulb that is used for the parking lights in the front?
My turn signals work fine in the front, so its not those.
Thanks!
s2jz is offline   Reply With Quote
Old 08-05-2008, 01:48 PM   #2 (permalink)
dezignpro04
All MOTOR S2K
dezignpro04's Avatar
Thanks!
Not sure, but wanted to point out that if both went at the same time, it is a rare occurance and could be a short or bad fuse you might want to look into.
Old 08-05-2008, 01:49 PM   #3 (permalink)
Grumpy old(er) phart
Thanks!
Here's the part breakdown. I did this for a '04 because I don't know which year you have but the bulbs should be the same... here is the parts breakdown
Old 08-05-2008, 02:10 PM   #4 (permalink)
phins2rt
phins2rt's Avatar
Sylvania has a decent replacement guide.
http://www.sylvania.com/ConsumerProd...lacementGuide/
02 S2000 Berlina Black/Black
08 Acura MDX
03 Acura MDX
phins2rt is offline   Reply With Quote
Old 08-05-2008, 03:10 PM   #5 (permalink)
s2jz
i have an 03, i think its one of the smaller bulbs, thanks guys!
Old 08-05-2008, 03:11 PM   #6 (permalink)
s2jz
its 7443 if anyone is curious.
