Old 04-28-2009, 07:31 PM   #1 (permalink)
Spartanic
Thumbs up S2000 DIY repair info in here, check it out
I wasn't too sure which category to put these DIY repair info in so I bunched them together into one post. Let me know if you guys see any errors. Writeups include F20C engine removal and installation, cooling system, lubrication, wheel bearings, etc etc.
The list of completed write ups:
S2000 Brake System
S2000 Cabin AirFilter
S2000 Cam Chain
S2000 Clutch
S2000 Interior Console
S2000 Cooling System
S2000 F20C Crank Pulley
S2000 F20C Cylinder Head
S2000 F20c Engine Install
S2000 F20c Engine Removal
S2000 interior dash removal. Garage411.com
S2000 Exhaust System
S2000 Horn
S2000 Hub Assembly
S2000 Ignition
S2000 Immobilizer
S2000 Lubrication system
S2000 Interior Seats
S2000 rocker arms. Garage411.com
S2000 Rear Suspension
S2000 Trunk
S2000 Universal Joints
S2000 F20C Valve Clearance
S2000 VTEC solenoid test
S2000 Wheel Alignment
S2000 Wheel Bearing
Critiques welcomed. More updates coming soon...
Spartanic is offline   Reply With Quote
bearing, body, cylinder, diy, engine, head, horn, install, interior, rear, removal, repair, replacement, s2000, wheel
