Old 05-16-2008, 09:39 AM   #1 (permalink)
jorx7
jorx7's Avatar
upgraded throttle body
has any one upgraded there thrttl body to a bigger mm. or the skunk2 racing one? pros cons? thanks
jorx7 is offline   Reply With Quote
Old 05-16-2008, 09:50 AM   #2 (permalink)
D1sclaimer
Mustang Killer
I wouldn't suggest the skunk2 throttle bodies from personal experience. They stick and have problems. They're the cheapest, but not worth it.
Are you NA or forced induction. If you're NA, don't get one. My MPG dropped alot when I put my 68mm on. It didn't really add any whp. Mayber 1-2. Its just not worth it for the price of gas.
Old 05-16-2008, 10:13 AM   #3 (permalink)
jorx7
jorx7's Avatar
thanks for the info. i think ill stick with stock.
Old 05-16-2008, 11:12 AM   #4 (permalink)
cbrguy7
cbrguy7's Avatar
skunk2 sticks so you have to adjust it right, Skunk2 is a clean setup, it relocated your wiring the the bottom side...
無限
cbrguy7 is offline   Reply With Quote
Old 05-16-2008, 11:37 AM   #5 (permalink)
J'sS2K
J'sS2K's Avatar
Unless your supercharged, I don't see the usefulness of a bigger throttle body. The engine is only going to suck in that much air even if the throttle is bigger!
Old 05-16-2008, 11:40 AM   #6 (permalink)
D1sclaimer
Mustang Killer
Exactly. The throttle body then gives the MAP sensor a higher reading and shoves fuel into the engine which makes you run extremely rich and can damage your cat, if you have yours on.
Old 05-16-2008, 12:31 PM   #7 (permalink)
I have a 66 mm throttle body. I works fine with the Mugen ECU but with the stock one causes a cel.
Old 06-02-2008, 10:59 PM   #8 (permalink)
Seattle2k
Energy Motorsports
Seattle2k's Avatar
BTW...these guys aren't far from me.
http://www.proflowdesign.com/tbha.html
PM me about discounts on Seibon carbon fiber and Tein lowering springs. www.energy-motorsports.com
Seattle2k is offline   Reply With Quote
