what do you need?
what do you need ofr a proper turbo setup besides:
turbo intercooler turbo manifold ecu tune like gauge wise and things like that...i am trying to see how much its gunna hurt the wallet to go f/i
I'm a math guy, but here's a way of explaining two ways to compare things, a simile, and a metaphor... Simile: VTEC is like sex Metaphor: VTEC is sex hmmm.why didn't they teach it this way in school? |
wastgate,bov,intercooler piping,downpipe,injectors,upgraded fuel pump,oil filter relocation kit.
Just a few things off the top of my head. |
Banned for Life
Killa knows this. He is heading this project as we speak. And actually he is only like 5 miles from my condo, and no call to see the car. I AM HURT.. lol
new list:
turbo intercooler turbo manifold ecu tune wastgate bov intercooler piping downpipe injectors upgraded fuel pump oil filter relocation kit i can't believe i forgot the wastegate....also do you HAVE to get a new fuel pump? anything else?
Sounds expensive. Is it worth it for a car designed for tracking and auto Xing?
its the cheapest way to add a lot of horsepower
LOL,I am working two jobs right now because things are tight. But It will be done soon and you can belive you will be one of the first to know.
Car Dummy
Sounds like you're on the right track.
Here are a few things that aren't 100% necessary, but would be a good addition: -Some sort of boost control, preferably electronic -Thicker head gasket to lower compression (if you want to run higher boost levels) -Larger diameter exhaust with no cat -Aftermarket clutch -Adjustable fuel pressure regulator -AEM 3.5 MAP sensor (doesn't have to be AEM) -Cooler spark plugs -Upgrade banjo bolts (if pre 2002) You will definitely need a higher flowing fuel pump. Gauge wise; wideband, oil pressure, and boost pressure will monitor some of the mainstream vitals in a forced induction application. |
kool i thin i got all the stuff inline now...thanx for the help
hey carguy where did you get your turbo thermal bag from?
Car Dummy
2JZ swap? Oh wait, you said cheap didn't you...
![]() 332hp/344tq - Stage One Tuned By Goodspeed Performance. http://www.goodspeedperformance.com http://www.myspace.com/dsi97 Honda Service Professional SanTan Honda Chandler, Arizona USA |
| boost, honda |
