Old 11-30-2008, 08:20 PM   #1 (permalink)
jake2k
jake2k's Avatar
few turbo Q's
have a 2002 turbo'd s2k and had a few questions
1) bought the car used with the charger so dont realy know what the numbers are dealer said 319 at the wheels but then again he is a car salesman lol how much is it to get it tune and dyno'd plan to do it this weekend if times allows
2) are turbo timers always a good idea regardless of boost or how you run the car. are they a must?
any info would be great thanks guys
"Dream as if you'll live forever, Live as if you'll die today." - James Dean
jake2k is offline   Reply With Quote
Old 11-30-2008, 09:16 PM   #2 (permalink)
D1sclaimer
FIGHT THE POWER!!!
D1sclaimer's Avatar
1. Depends on the turbo kit about how much power. Sounds about right for a straight bolt on turbo with a small tune. It all depends on the tuner you use and how good (reputation) he has. Around me, tuning is 150 dollars an hour.
2. I'd get a turbo timer. It'll circulate oil through the turbo after you take the key out and shut the car off on its own. You don't want hot oil just sitting in the turbo and burning up. It'll give your turbo a longer life span.
i only date fat chicks.
Old 12-01-2008, 07:01 PM   #3 (permalink)
jake2k
jake2k's Avatar
thanks for the info and it's a greddy kit. I'll start looking at timers to see what they have any recomendations?
Old 12-10-2008, 06:50 PM   #4 (permalink)
S2k675
Your better off getting the timer unless you are patient and don't mind letting the car idle for a few minutes while you sit there. Also I would make it a point not to load the engine/boost when your about to reach your destination to keep the turbo's Rpm as low as possible before shut off.
S2k675 is offline   Reply With Quote
Old 12-11-2008, 08:05 PM   #5 (permalink)
sbrodacz
sbrodacz's Avatar
Don't waste your money on a timer. If you're really beating on the car you just have to have to let it sit for 30 seconds. If you're beating on it on the street just take an easy when you get close to your destination. For example, if I'm boosting on the street heavily and then turn on my street, by the time I'm at my drive way it's been enough time to let it cool.
sbrodacz is offline   Reply With Quote
hot, run, s2000, turbo
