Old 09-17-2009, 10:31 PM   #41 (permalink)
It doesn't matter whether you cover the metal tube or not. The heat soak will happen if the tube is a good thermal conductor. Some of that happens to anything in a warmer than ambient environment, like an engine compartment. But insulators like plastic and dry carbon weave absorb a lot less heat. Add a little thermodynamics to your life.
2008, adapter, aem, air, apexi, cold, factory, intake, jdm, kn, nitrous, password, s2000, system, upgrade
