Old 06-24-2009, 06:01 PM   #1 (permalink)
ironpumper
after comtech s/c install, ecu is confused
I just had installed a brand new comptech s/c,
instead of +80 to 100 added hp, I have a drop
off of 20hp overall (sad but true). The dyno shows
the drop off at 4000 to 6000 rpm. this is below the
VTEC take off at 6600 or so. the vtec doesn't really
engage.
The installer is competent. His advice is drive the car
for a week or so and see if the stock ecu wakes up
and resets itself to take advantage of the new boost.
(dyno shows the boost is flat and steady at +5 psi).
I did have an apexi installed. it was disconnected
because Comptech suggested a return to a clean
ecu configuration before making mods.
does anyone have experience with an ecu reset/re-flash
or this type of occurrence ?
ironpumper is offline   Reply With Quote
Old 06-24-2009, 06:08 PM   #2 (permalink)
tuna79
tuna79's Avatar
That is a weird reaction to boost. Is it just dumping fuel and running way too rich? You might try disconnecting the battery for a minute then reconnecting and run the car hard to set the ecm for a new fuel map. Good luck.
tuna79 is offline   Reply With Quote
Old 06-24-2009, 06:46 PM   #3 (permalink)
an easier way to reset the ecu is to look at the fuse panel under the dash and pull the fuse thats all the way to the left and second fuse down. Also what was your max whp you made?
2001 Vortech SC
12.8 at 111 miles per hour
Old 06-24-2009, 07:41 PM   #4 (permalink)
ironpumper
reply
my peak hp was 205 before the s/c
now it is 180 or so
i disconnected the battery and then ran it a little hard.
it seemed to improve, but had some hestitation in the 5 to 7
thousand rpm range. i do feel an increase in hp in my butt.
but the system is not yet stable.
sugesstions??
Old 06-24-2009, 07:48 PM   #5 (permalink)
youre only making 180?????????? Something is very wrong and its not that your ecu needed to be reset. A good installer/tuner would have told you that. Have you hooked a wideband up to it yet?
2001 Vortech SC
Old 06-24-2009, 08:07 PM   #6 (permalink)
MutantCheese
The Cheeziest!
MutantCheese's Avatar
I agree, something is def wrong here. You should be giggling like a school girl right now.
2008 S2000 New Formula Red (K&N FIPK; Berk Ceramic coated SS headers; Berk SS HFC; Tanabe Concept G SS exhaust; Hondata toda Reflash; OEM front lip); Eibach Prokit lowering springs
2006 Civic Si NBP w/hfp kit (Too many mods to list here)
2008 CR-V EX-L w/Nav
Visit: www.GNOunderground.com
Old 06-25-2009, 11:23 AM   #7 (permalink)
hivolume.com
engage.
Do you know how many actual PSI you're running? I mean an actual reading from a gauge, not just what it says in the install manual. This could give an indication for a boost leak or spikes.
hivolume.com is offline   Reply With Quote
Old 10-30-2009, 08:55 AM   #8 (permalink)
S2KCRick
The Myth
S2KCRick's Avatar
So whats the end result for this?
Originally Posted by lonestarbuzz View Post
hrm, i've been thinking about doing this for a while. how's the gas mileage compared to the s2000? i never drive in vtec, so that's not an issue. i like how cute the miata is too, the s2000 is just a little manly for me.
Old 10-30-2009, 09:55 AM   #9 (permalink)
Well he hasn't been back on the site in 4 months so I doubt we will find out any time soon.
5psi, boost, ecu, flash, fuse, honda, install, leak, located, reset, s2000, vortech
