When to go FI
Ok, this is the deal. I've got my heart set on supercharging my S. So far I got the stage 3 clutch, forged pistons and studs, iron sleeves, and a thicker head gasket. Just need the exhaust (right?).
The car is an 03 with 74,000 miles. By the time I get the funds together, I'd probably have about 84,000 miles, and the car would be paid off by then. My question is; Would 84,000 miles seem too high for FI? What mileage were you guys at when you went FI? |
I have seen guys go much higher miles on a S/C, tech you really dont need anything for say a comptech or the older vortech s/c you can run stock clutch for a while but it will probably begin to slip "eventually" If your trying to go for the really high HP in the 400whp range you will need bigger injectors EMS and the clutch which you already have.
There are people running fi and making alot of power with over 100k miles.
FIGHT THE POWER!!!
So you got forged pistons and a thick head gasket?
From what I've seen on this forum, people are just bolting on Vortech s/c and that's it. Stock everything else.
Varietas Delectat
Sounds like you've got a built block. I don't know how much boost you want to push but other than check and/or update the retainers to the ap2 ones, you're ready to go with some higher boost.
I boosted mine on a stock vortech at 10k. Now it's much more modified at 50k and my compression and leakdown tests look great. I do them every year and write the results inside the plug cover. Run those tests on your motor before you begin and that will tell you a lot about it's current state. I'm assuming you haven't installed any of the components you already have. fltsfshr |
Everything I mentioned above is already installed. So, I guess it can be considered "built". They been on for about 10 months. One of these days I'd like to dyno it and see if there are any gains. My mechanic said that there would be only like 5 or so, but it feels stronger.
Right now I am sure that it can take a lot of boost, but I think I would be comfortable with 325 hp to the wheels. Hmmm. come to think of it, I've never been in a boosted S2000 before. I am looking forward to it. |
FIGHT THE POWER!!!
So what pistons did you get? What CR? If you got 9:1 CR pistons which a lot of turbo guys get you don't need a thick head gasket.
You can put down 300 WHP with an aftercooler and 7 lb pulley. Larger injectors were good for an extra 15 WHP (total 315) for me, but the street drivablility suffered so I had them taken back out.
do it, cop!
The Myth
yea do it! do it!
have it dyno'd before and after too. |
go FI ASAP.
#13 (permalink) | |
Is an exhaust ABSOLUTLY necessary? Or will the stock one do? |
You dont REALLY need an exhaust.. I mean it may help but its not the end of the world if you dont have one
The Myth
I didn't put an aftermarket exhaust on mine. I want mine to be quiet so I can hear the SC whistle.
#16 (permalink) |
no reason to dyno it now. if it has 9:1 pistons and a thicker HG then he's nowhere near 240hp as he stands...
#17 (permalink) |
The Myth
Maybe its nowhere near 240hp, but I would still want to know how much hp its putting out before the SC. At least i would.
#18 (permalink) |
Varietas Delectat
I'm guessing about 150 rwhp. I think your build costs with an SC are going to be expensive to get it up the hp you want. You maybe should reconsider a turbo instead of an supercharger. Probably do it cheaper.
fltsfshr |
#19 (permalink) |
he can always compensate with a smaller pulley
#20 (permalink) |
150 whp? Not likely. There's a strech of road on the way to my dad's that I used to hit XX miles per hour on before the repair, on average. Now it's XX+6, on average.
After doing some searching online, I think I will go turbo. I like Inlinepro's Stage 1 kit. How much hp does it make? Or does that depend on the EMS (thinking about Kpro from Hondata)? |
#21 (permalink) |
no kpro for you mr ap1
AEM 1052, have t1r in rowlett tune it, tony palo is a bad ass
#22 (permalink) |
The Myth
COP, have you lookd at the Kraftwerks kits or Vortech kits?
Check here: http://cms.kraftwerksusa.com/ and here: http://www.vortechsuperchargers.com/view.php?pcat=15 |
#23 (permalink) |
The Myth
the complete V-3 SCi-Trim Vortech kit should get you close to 325hp. You'd be looking at $6k installed, by a Vortech certified top tier installer, less if you have a non-Vortech installer put it on. No tuning required with the complete kit.
Vortech tuner kits are about $4.2k |
#24 (permalink) |
what is the difference between the V-2 and the V-3 superchargers, 7 lbs.? How is Vtec affected with FI?
#25 (permalink) |
the v2 are super quiet supposedly, dunno anything else, nothing else look diff on the site.
#26 (permalink) |
the v3 says sealed gear housing
maybe the v2 uses engine oil and the v3 doesnt? hmmm.
#27 (permalink) |
The Myth
Yup, that's what i think too. Mine is V3 which is self lubricated.
#28 (permalink) |
i dont give a shit about noise, a sealed gear housing would win it for me, no tapping the oil pan or any of that jazz. they are both spec'd out the same other than that.
#29 (permalink) | |
The Myth
I'm at 8psi. Since my kit comes with the Hondata reflash, vtec was changed to 5800rpm. Hondata reflash is only for 06-08 i think. |
#30 (permalink) |
The Myth
The noise bothered me when i first got her back, mostly because i wasn't expecting to hear anything from the SC, now i'm used to it and kinda like it. Its not too loud, but anyone close by and knows what an SC sounds like is gonna know you have one.
