Go Back   S2000 Forums > Honda S2000 Classifieds > Gear and other merchandise Sales
Gear and other merchandise Sales Find gear, accessories, and other merchandise for sale here.
Old 07-13-2008, 05:20 PM   #1 (permalink)
bobby2002S2K
bobby2002S2K's Avatar
IBA + one front plate $350.00
It has nothing to do with the S but hey if you ever need to stop a 7.62 round i got whatch need.
The Interceptor body armor system consists of an Outer Tactical Vest (OTV) and two Small Arms Protective Inserts (SAPI). The OTV is lined with finely woven Kevlar KM2 fiber. These two parts of the vest are both bullet and heat resistant. The vest was tested to stop a 9 mm 124 GR full metal jacket bullet (FMJ) at 1,400 ft/s (426 m/s) with minimal deformation and has a V-50 of roughly 1,525 ft/s (465 m/s). This means that the bullet has to be traveling faster than 1,525 ft/s for it to have more than a 50% chance of breaking through the armor panel. These plates also come in five different sizes and go into the front and back of the vest.
The Interceptor can not, however, be called a Level III-A vest as military standard does not require protection against heavy .44 Magnum ammunition. However, both Level III-A vests and Interceptor do protect from much lighter 9mm threats in identical tests. The vest will stop other, slower-moving fragments and is also equipped with removable neck, throat, shoulder and groin protection.
Two small-arms protective inserts may also be added to the front and back of the vest, with each plate designed to stop up to three hits from 7.62×51 NATO (.308 Winchester) M-80 ball ammunition, with a muzzle velocity of 2,750 feet per second (838 m/s). The plates are the most technically advanced body armor fielded by the U.S. military, and are constructed of boron carbide ceramic with a Spectra/Dyneema shield backing that breaks down projectiles and halts their momentum before reaching the wearer.
The Interceptor armor also has a PALS webbing grid on the front of the vest which accommodate the same type of pockets used in the Modular Lightweight Load-carrying Equipment (MOLLE) backpack/carry vest system. This allows a soldier to tailor-fit his MOLLE and body armor system to meet mission needs. While not specifically designed for it, the loops can also easily attach All-purpose Lightweight Individual Carrying Equipment (ALICE)-based equipment, MOLLE's predecessor, as well as many pieces of civilian-made tactical gear, and also features a large handle on the back just below the collar which can be used to drag a wounded wearer to safety in an emergency. The Interceptor vest comes in various different camouflage patterns, including U.S. woodland, three-color desert, and the Army Combat Uniform's new Universal Camouflage Pattern, as well as Coyote Brown.
The Interceptor Body Armor system weighs a total of 16.4 pounds (7.4 kg), with the vest weighing 8.4 pounds (3.8 kg), and two plates inserted weighing four pounds (1.8 kg) each. This is considerably lighter than the previous body armor fielded in Somalia weighing 25.1 pounds (11.4 kg) that most troops complained was too heavy and unwieldy for combat operations.
Here is a link same as picture. http://en.wikipedia.org/wiki/Interceptor_body_armor
Ive had it laying around in closet along with alot of other military gear i have aquired over the yrs and now i have figured out that i dont need all this stuff. So if anyone needs some military crap pm me and i will see what i got or close to it.
Old 07-13-2008, 05:43 PM   #2 (permalink)
philiam
Might come in handy for the freeways around here. It is shooting season.
