View Full Version : Engine Tech / Drivetrain
Pages : 1 [2] 3 4 5
  1. tanabe concept g exhaust
  2. VSA
  3. Fuel pump problems HELP
  4. synth oil change interval ??
  5. Help me guys, 5th gear is gone
  6. oil/trans/fuel additives???
  7. Clutch problems?
  8. Oil change Experts Please
  9. Tranny/diff fluid change
  10. Funny Noises
  11. Non-Carbon Fiber Air Duct
  12. For those of you with Comptech Intakes!
  13. Rough Shifting
  14. Another funny noise
  15. Floor clutch??
  16. Still wondering about first oil change.
  17. JDM Air Duct
  18. short ram vs full intake
  19. Transmission Fluid
  20. Need to know!!
  21. Exhaust?
  22. Mileage in winter
  23. individual throttle bodies
  24. DO I HAVE LS
  25. Free Mods?
  26. looking for quite like catback system
  27. s2000 Air Intake Installtion
  28. what kind of clutch do u have?
  29. VTEC not engaging
  30. j's or toda
  31. My Dream F22c dyno...
  32. hks exhust
  33. Underdrive pulleys and s2000
  34. Non F20C/22C problem lol
  35. vsa help
  36. VTEC issues
  37. engine size
  38. PROBLEM!!! :/ loud engine
  39. tanabe medallion touring
  40. Clunking sound going into 1st gear
  41. Check Fuel Cap
  42. Test Pipes
  43. spoon propeller shaft
  44. HElP ASAP
  45. Is my clutch slipping or something else?
  46. engine light problems
  47. VALVE ADJUSTMENT
  48. Turbo
  49. anyone have a used supercharger for sale?
  50. code 1456
  51. REV. LIMITER
  52. Engine rattling sound at 9k miles
  53. stahling out
  54. Reset Oil Life Meter
  55. mobil 5W-30 non-synthetic
  56. Check Gas Cap (again)
  57. what yrs for the engines???
  58. So I Removed The Airbox Lid.......
  59. Test Pipe???
  60. Rear end squirly when cold?
  61. Tranny help
  62. Check Engine Light due to test pipe?
  63. aem plug n play neptune
  64. Lots of DIY
  65. New Exhaust, Tuned Sound But Not Stupid Loud......
  66. Which Years Engines Are The Same???
  67. V Tech Engine
  68. Check Engine Light after oil change?
  69. s2000 is scary.
  70. valve adjust problem...
  71. Oli Change ??
  72. Centerforce DF clutch
  73. ek fog lights on a ap1?
  74. 21/2 exhaust question
  75. New Honda MTF Trans Fluid
  76. mod question
  77. Vtec question
  78. power chip on ebay
  79. Gearhead details for our engine/transmission
  80. Check engine light (p0141)
  81. How much HP?
  82. Clutch Question
  83. Good exhaust?
  84. Shift Points
  85. Going to look at an S2000 today, need your advice.
  86. lifter problem help!
  87. stay away from the greddy emanage???
  88. CHECK ENGINE LIGHT!!!
  89. Whining Noise from the rear!
  90. CHECK ENGINE LIGHT PT 2!!
  91. 2001 Engine Replacement
  92. Pulstar Plugs?
  93. Magnus Intake manifold
  94. Need 2.5 stroker performance information
  95. 2008 model with AP1 engine
  96. Diff Oil
  97. Faster acceleration ( slightly)
  98. vibration ???
  99. Check Engine Light On
  100. Engine torque dampener?
  101. K&N intake kit
  102. Heading for trouble?
  103. Cooler thermostat
  104. Intake manifold ( light weight and enclosed)
  105. Oil Leak
  106. Intake manifold
  107. exhaust
  108. Noise coming from the back...
  109. ARC intake??
  110. im so mad, new use car and theres something wrong!!!
  111. Looking For A Dyno Graph On A Stock '07 S2K
  112. 2004 diff fit a 2000
  113. do ya have extended warranty with them too?
  114. SKUNK 2 THROTTLE BODIES?
  115. weird sound when decelerating
  116. Invidia vs. T1R
  117. where to get harness?
  118. will these PARTS WORK ap1/ap2
  119. cold air intake----> blown engine
  120. hell in cali...
  121. 03 Tranny Problems (Rating)??
  122. AP1 68mm Throttle Body Review
  123. New S2000 vtec question....
  124. Getting Burned.
  125. Stock Block question
  126. Oil Leak
  127. Just a quickie question bout test pipe
  128. Dang!
  129. ACT clutch questions!
  130. Transmission Fluid
  131. CEL came on :(
  132. maint req'd light
  133. want a turbo
  134. Performance chip fo a 06 S2k help please
  135. engine management for an 08?
  136. How often do you change Engine Air Filter?
  137. ap2 ecu in a ap1?
  138. OBD2 location
  139. Individual Throttle Body Question
  140. Clutch Costs
  141. 2JZ engine in S2K
  142. exhaust
  143. S2K 2JZ SWAP INFO
  144. looking for exhuast most power gain
  145. engine swap for cheap?
  146. I am about to buy a s2000 Help please
  147. engine fuel cut off and timing belt
  148. clutch delay valve
  149. ??CABLE CLUTCH??
  150. forums
  151. Check Engine Help Please
  152. My oil drain plug popped out!
  153. installed my new exhaust
  154. has anyone heard of the stock block going boom?
  155. increase Torque
  156. rearend noise
  157. HELP PLEASE !!! Can my Block be SAVED ??
  158. Installed an AEM...
  159. Fujita F5 bypass valve?
  160. magnus intake manifold
  161. new Invidia exhaust
  162. S2000 ECU Help
  163. Knock on wood
  164. Headers
  165. shifting to fast????
  166. CARBON FIBER COOLING PLATE...
  167. cold air intakes
  168. xlevelonline.com
  169. VTECH GOING OUT
  170. switching to full synthetic
  171. Anyone Ever Heard of Tsudo Exhaust?
  172. check engine light
  173. Smooth idle??
  174. Differential help
  175. maintenance Req. light
  176. Vtec controller
  177. EPS- Electronic Power Steering
  178. venom 400 control module
  179. Engine Rebuild
  180. Serpentine Belt
  181. GReedy Emanage Ultamite
  182. uhh...
  183. Berk High flow Cat
  184. Possible rough idle fix
  185. secret compartment
  186. rear gears?
  187. Break in of engine
  188. Awkward shake from complete stop
  189. Hard Numberz Anyone?
  190. Pulsestar plugs
  191. Invidia V4 install and sound clip
  192. stock fuel pressure
  193. me again!
  194. WHO HAS THE HIGHEST MILEAGE THREAD
  195. Ebay go fast, ultimate wrench
  196. Exhaust Opinion
  197. Looking for some good pipes!
  198. clutch question
  199. test drove a S2000
  200. question regarding tranny noise
  201. Clutch problem
  202. Ticking engine
  203. engine oil capacity ?
  204. Apexi Neo
  205. Tranny Question
  206. Rear Bearing noisy in Tranny, anyone had similar issue?
  207. Swapping out 6th Gear
  208. Occasional Low Idle
  209. MEGAN RACING 4-2-1 HEADER??
  210. What would you do next?
  211. throttle body spacer???
  212. flywheel bolts
  213. New clutch
  214. best engine management?
  215. fuel pump
  216. Transmission Noise
  217. Misfire07s2kturbo
  218. Using regular unleaded instead of super?
  219. Better cap?
  220. Timing Chain
  221. Oil change intervals
  222. Oil change Ask
  223. Anyone know anything about this intake?
  224. cable clutch
  225. My NEW EXHAUST - Check it out!
  226. What do you guys think of J's Dual exhaust
  227. Clutch/shifting issues
  228. My first oil change ever.. needs help and advice
  229. Gotta problem.
  230. Small Squeal
  231. 110 Octane - Questions
  232. 2.4 liter S2000
  233. High Mileage Oil
  234. Top 5 Upgrades ???
  235. tranny grinding in second gear
  236. Exhausts so hard to pick!
  237. Clutch
  238. this has to be the funniest thread ever!
  239. Cylinder 4 Misfire - ??
  240. Sqeeking Clutch Pedal
  241. OEM NGK Plugs - Always price around!!
  242. sr20det s2000
  243. invidia exhaust question
  244. Berk High-Flow Cat
  245. If your fast you've got time to buy. 00-08 S2000 s2k New Invidia Q300 V4 Dual Exhaus
  246. S2000 rpm limiter
  247. got another problem...
  248. Infamous Squeak
  249. New engine management system
  250. Throttle body question
