View Full Version : Engine Tech / Drivetrain
Pages : 1 2 [3] 4 5
  1. K&N Filter ... Where to get?
  2. ok to put in 87 ocatane gas?????? or bad for engine?
  3. mant req lite
  4. Shot Shift
  5. big brake kits
  6. Exhaust Weights?
  7. I NEED A REAREND, and PASS SIDE LOWER CONTROL ARMS FRONT AND REAR!!!!!!!!!!
  8. Boy the Seats are great...
  9. Idling RPM for your engine
  10. ECU
  11. Fluid Capacities?
  12. On-line owners manual
  13. More speed
  14. I really need help! Please Read.
  15. oil change stuff
  16. F20 v F22
  17. Fuel injection cleaning question.
  18. Invidia 70mm test pipes, HS00HS1TP2 or HS00HS1TP3
  19. what type of brake fluid to use for clutch?
  20. Vibration during acceleration
  21. how hard are fuel injectors to install!!
  22. Click sound on driver side rear tire
  23. S2000 Breaking / Dismantling !!!!!
  24. Maintenance Required Light, Please Explain
  25. VAFC II
  26. heat soak
  27. Rattling noise coming from top tensioner!
  28. MTF & DIFF Fluid change interval
  29. Will exhaust void warranty?
  30. Engine problem
  31. test pipe?
  32. ecu location?
  33. will a 2003/4/5 gearbox fit ap1 1999 !
  34. Different Spark Plugs Dyno'd
  35. Fuel System problems.
  36. Intake filter question
  37. Valve Cover AP1 vs AP2
  38. Porting
  39. Intake question for 08
  40. S2K with Redline oil USERS come help!
  41. upgrading my s2000
  42. Ticking noise?!?!
  43. CEL code P1104
  44. s2k redline shockproof gear oil
  45. Knocking noise from the rear end
  46. i need clutch help
  47. AEM CAI filter cleaning... need help!!!
  48. No Throttle Response
  49. stroker kit
  50. Can someone help me identify these parts
  51. Over revved due to miss shift 3rd to 2nd Need Advice
  52. Megan Headers
  53. f20 or f22?
  54. performance chip?
  55. Oil Leak...
  56. Interesting Vtec crossover info
  57. My s2000 smells
  58. OBD 2?
  59. 2 questions. Tranny and spark
  60. 1 st & 2nd gear trouble
  61. S2k..125,000kms... What to replace, change or service!!
  62. Maintd Requrd Light Flashing ON engine Start.. AND ANOTHER QUESTION
  63. REAR END GEAR CHANGES
  64. 11HP intake group buy??
  65. Clutch Upgrade?!
  66. GEAR OIL FOR REAR END?
  67. Short Shifter
  68. aeromotive 1:1 FPR on NA ap1?
  69. FULL exhaust..
  70. 1/4 Mile
  71. Faster
  72. 1/4 Mile
  73. Engine Light
  74. S2000 is hurting
  75. Oil filter
  76. Hey
  77. Where to find J's Racing 70RS exhaust?
  78. I Need Your Expertise
  79. gearbox and diff oil!
  80. Question about CAI
  81. Loud Clunk sound when engaging Reverse
  82. My car stops pulling around 8000 rpms...why?
  83. What are these Gizmos?
  84. What clutch do you guys use and why?
  85. Christmas came early this year
  86. Need a little input plz.....
  87. Notchy 'box on 08 car
  88. Stock box
  89. Need Help
  90. F*&K
  91. Compression test numbers
  92. Damn CEL again!
  93. Cat Back Shopping
  94. Weird sounds coming from my engine, NORMAL!?
  95. ARC air induction
  96. Tippin' the scales
  97. Oil life indicator and other annoying things
  98. Good news and Bad news...
  99. Cold Air Intake (need help)
  100. Changed clutch now Check Engine Light comes on
  101. tranny noise
  102. Battery appears to be dead
  103. need advice on this master clutch cylinder
  104. comptech charger !
  105. maintenance required light and backfiring when cold
  106. Changing spark plugs
  107. Best upgrades for $1500
  108. Differential Mounts leaking
  109. Invidia Exhaust
  110. AE86+f20c, need some help with my swap
  111. Engine Knocking Advice
  112. I heare the valves at high RPM shifting, but rarely
  113. AP1's Burn Oil?
  114. ap1 spun bearing
  115. Did anyone try the electric supercharger yet?
  116. Stock airbox for sale
  117. Single Click sound from Axle area
  118. How to add Trans fluid?!?
  119. Clutch Noise?
  120. Honda V-8
  121. ~~>NEWBIE WITH A QUICK Q???
  122. carsponsorships.com
  123. Clutch help
  124. ap1 engine swap into 73 mgb
  125. rattle when started
  126. Engine Damper Kits
  127. Loosing 2nd gear
  128. Removing Front Lower Control Arm
  129. Best Stage II Clutch?
  130. MTF fluid ROCKS!
  131. What do you think, to much red?
  132. Check oil when engine is running
  133. First 5000 Miles.. Now what
  134. I found something on my rt front spring
  135. Whats the Best Way to Ship Engine
  136. t1r header info
  137. A.C. Removal
  138. Ok guys...HELP ME DECIDE ON A FINAL INTAKE
  139. TEIN Hood Dampers
  140. 2005 Honda s 2000 complete abs system with master cylinder
  141. 2005 Honda s2000 fuel pump WITH complete housing and pick up screen
  142. 2005 s 2000 drivers side window and motor Assembly
  143. C.E.L code p170 & p172
  144. Bolt on turbo
  145. O.E.M. vs. ACT Clutch Parts
  146. Greddy TIC vs Greddy EVOII vs Tanabe concept G
  147. bolt on turbo, any other ideas?
  148. XTR Clutch
  149. First F1 Dual exhaust
  150. REAR DIFF
  151. Hot Parts Site!!!!!!!!
  152. VSA was sent by the devil...
  153. Pure Power Oil filter
  154. Air duct Chamber/K&N Intake question.
  155. Curb Damage...Opinions please?
  156. lowering springs
  157. need help 6al msd ignition
  158. 300 crank HP all motor doable?
  159. Good deal if you can weld
  160. engine noise at start up
  161. problem reving engine past 3000 rpm
  162. OPINIONS ON INVIDIA EXHAUST?!
  163. OPINIONS ON TANABE CONCEPT G EXHAUST
  164. How to adjust KW V3 coilovers?
  165. 06 ap2 into 01 ap1 engine swap issues...
  166. Cool article on oil breather and blow by gas
  167. Header Back System
  168. Transmission won't go in! HELP!!
  169. mesh grills
  170. Help...
  171. s2000 repair manual 2000-2003
  172. AP2 trans swap in AP1 - same driveshaft?
  173. Can you Guess what this sick turbo set-up is on?
  174. Stewie in the shop :(
  175. Brian crower stage cams and valves springs & retainers
  176. Test pipe question.
  177. Clutch mod / question...
  178. Thup sound when put in 1st...
  179. valves and timing chain
  180. Broken Axle
  181. Forced to upgrade
  182. JDM speedcut removal
  183. Problem with Bushings
  184. Finally i Got The New Rear Diff
  185. bad cylinder head???
  186. greddy E-manage ultimate
  187. Replacing K&N air Filter
  188. me again
  189. Differences between K&N intakes???
  190. Stewie been gone too long!
  191. Here is a V-8 That keeps the S Factor Feeling
  192. S2000 rough idle& tap ( long read)
  193. Is it the Starter or the Flywheel?
  194. Exhaust opinions
  195. im pretty excited
  196. White Smoke
  197. NAME THAT EXHAUST "Tanabe"
  198. me again
  199. MISPRINT???? OR What
  200. Front o2 sensor??
  201. 08' intake manifold on an 03'
  202. Installing clutch
  203. Clutch master cylinder leak?
  204. ? on doing a compression test
  205. Another Tranny / Diff thread!!
  206. Some Stripped Pics
  207. Cold Weather Starts
  208. test pipe ????
  209. Crazy Transmission Problem
  210. intakes and exhausts
  211. Tsudo exhaust
  212. R.I.P. S2K
  213. Gutting the stock air box
  214. should i buy this s2000 with 105k
  215. Charging Question!
  216. Clutch ?
  217. 2002 s2k 1st gear tremble... Clutch? No fuel? Please help!
  218. ABS Light on HELP!!!
  219. drive shaft????(video)
  220. Help with ITB's
  221. Anybody ever hear of this??
  222. 07' Cylinder Head 4 sale!!
  223. Oil on one of my spark plugs...?
  224. tuning my s2000
  225. Mod questions
  226. Vtech Controller
  227. engine ck light after changing spark plug
  228. Oil gauge may be off...
  229. Can I expect power from..
  230. Clutch
  231. Unidentified pipe
  232. Maintenance required light
  233. 2000 model year advice
  234. Two questions: VSS & 02 sensors
  235. How loud is your transmission buzz / clutch rattle? (Videos included)
  236. MPG Question... I dont want to hyjack a thread...
  237. Help before tomorrow morning, strange pulsating vibration
  238. crap
  239. spark plugs
  240. check engine HELP
  241. CHanging fluids and Maintenance
  242. 2 problems wid ma s2000
  243. engine problems wid 2000 model s2000s
  244. s2000 problem again
  245. Swapping out tranny next weekend...
  246. 2nd & 3rd whine?
  247. Recent Pix of Motor Teardown
  248. Rod/Main Bearing Replacement question
  249. Do I have an LSD...?
  250. MTF
