View Full Version : Engine Tech / Drivetrain
Pages : 1 2 3 [4] 5
  1. Mystery solved!!
  2. New oil!
  3. 02 Sensor bad ---question!
  4. Pulstar Pulse Plugs
  5. 2001 s2000 random misfire CEL:p1339
  6. Mixed Matched Spark Plugs
  7. Exhaust tips
  8. Flowmasters... To be or not to be?
  9. rear-end go BOOM!!!!
  10. clutch questions
  11. Intermittently Slips out of Second Gear
  12. High Idle
  13. Coolant
  14. Test pipe with stock look
  15. Wierd Sound Under the Hood...?
  16. me again
  17. me again
  18. PCV Help
  19. indvidia exhaust
  20. how low can i go?
  21. high idle 2
  22. Gear ratio calculator
  23. engine swap
  24. Horrible problem NEED HELP!
  25. Need to mod my S2000
  26. Low clutch or tranny problems????
  27. light grinding noise from rear
  28. Valve adjustment question
  29. Factory setting - throttle plate
  30. can i get a new ecu for my s2000
  31. Anyone have their diff not break?
  32. New Honda MTF question...
  33. another diff question
  34. 2.2 I-vtec 6spd trans need help
  35. newb question
  36. need help on how to fix cel code 113
  37. How much for a new clutch
  38. My engines running like a dog, please help....
  39. Request - Remus Exhaust Sound Clip
  40. throwing some codes
  41. test pipe now engine light!!
  42. Need help with adding mods to car
  43. Oil...
  44. Throttle body installation question
  45. FlywheelS
  46. low rev's it goes crazy
  47. My baby coughed and died!
  48. oil light.
  49. 6000 rpm and......nothing
  50. Exhaust system that looks and sounds stock
  51. Belt Tensioner noise
  52. 2nd gear will pop out
  53. High pitch whine
  54. Tenabe Touring exhaust on an 06 app 2
  55. New S2k Owner and new to S2000.com
  56. HELP - is dis fo realZ?
  57. Clutch design question.......
  58. OEM Clutch Kit Question
  59. CHOZN A NTAK
  60. How Should It feel when you shift!?!
  61. driving barefoot helped me find out my clutch master cyl is leaking...
  62. VSS wires need help
  63. clutch buzz?
  64. Injectors
  65. apex ws 2 dual exhaust
  66. TEST PIPE HELP!
  67. Getting a Chip for my AP1????? Help???
  68. Power Gains on a S2000
  69. power-on vibration from the rear.... bad CV joint?
  70. bolt on enhancements
  71. Low Oil!
  72. Invidia Q300 V4 Dual Exhaust 70mm (Some tweaking required...)
  73. How do i make my s2000 sound deep? Muscular? Kinda like a V8 but not really.
  74. Need to upgrade clutch for SC
  75. anyone here running an 8lb flywheel?
  76. Top Speed
  77. Changed the Transmission Oil
  78. Need some help!
  79. My First Mod!
  80. exhaust vibration
  81. NEED HELP Engine Won't Turnover
  82. My S2000 plan.
  83. MAX POWER
  84. repair manual
  85. K@N Intake deal and Exquast pics
  86. Need Advice on Car not starting HELP HELP
  87. Need Help!!!!!
  88. Help / advice / comments: rattle / vibration noise during engine breaking
  89. Does anyone know the stock fuel pressure?
  90. Top speed Issues
  91. blow'n motor, nooooooo
  92. Smog/Idle Emissions/O2 Sensor
  93. New rear tires, car handles terribly and VSA light keeps coming on - MY06 S2000
  94. cam tech
  95. Aftermarket Spark Plugs
  96. Stewie gets fixed!
  97. A/C eliminator drive belt?
  98. Ls1???
  99. Grinding noise in reverse or 1st
  100. Broken S2000
  101. Clutch Change Procedure Question
  102. A mystery I'm not gonna solve.
  103. s2000 nissan diff
  104. Engine Restore?
  105. frustrated!! bled brakes and now the pedal is mushy HELP!!
  106. Engine Light
  107. Check Engine Light Came On aHH OHH
  108. Does AP2 oil pan fit AP1?
  109. Anyone ever replace just the clutch disk?
  110. I want to edit the pages in the service manual PDF. ITS TOO BIG
  111. ap2 bottom end ap1 head '08 f22 (will it work)
  112. Is this swap possible
  113. another diff. question
  114. wanna join s2000 family, but!
  115. Im going to go crazy with this car!!!!!!
  116. How to reset the "Maint Req" light
  117. HELP!!!!! My car needs maintenace!!!
  118. diff?
  119. Hit rev limiter 2x, did I hurt anything?
  120. Clicking noise when I shift
  121. test pipes?
  122. Engine too hot
  123. Which Exhaust?
  124. Radiator cracked
  125. Lightweight Flywheel???
  126. S2000 DIY repair info in here, check it out
  127. light weight pulleys
  128. Is this oil pan cracked?
  129. if my master clutch cylinder is going?
  130. New Member: Urgent Question about rear Noise
  131. sticky clutch pedal
  132. K@n Filter VS FIPK
  133. Nvidia N1... you have to be kidding
  134. Knock Sensor
  135. resonator question!
  136. New ACT clutch installed
  137. Slipping Clutch RIGHT?!?!
  138. Picking out a new Clutch : (
  139. Buckin' bronco
  140. Strange noise
  141. Magnaflow Exhaust on 2006-2008
  142. ARC Filter
  143. New Engine Noise
  144. exhaust question
  145. DTC ABS reset
  146. Blown Spark/Coilpack (Pict)
  147. Car stalls when in neutral and vtec not engaging
  148. 2006 s2k Engine Noise
  149. Funny engine noise
  150. Opened up the trans
  151. Air fule ratios
  152. Ebay turbo kit
  153. Installed the V2.......
  154. bolt ons
  155. Clutch Delay Valve?
  156. Taking off mufflers. Will it mess up performance?
  157. 2001 s2000 cranks, bucks and no start?
  158. Performance Loss
  159. Abomination!
  160. My S sounds like a diesel car...
  161. misfire in s2k need help!!!!!!
  162. turbo kit
  163. It's finally been done AND finished!
  164. New engine diagnosis......opinions????
  165. HELP ME PLEASE...EVEN HONDA CANNOT HELP ME.
  166. full synthetic diff fluid?
  167. rpm's
  168. Honda's new MTF
  169. just purchased a comptech s/c kit with after cooler need advice on how 2 beef up rear
  170. A hard sound to ID
  171. wanna take out o2 sensor
  172. Clutch needed recommendations please
  173. eps light..plz help
  174. vtec controller
  175. Fast Shifting gone bad
  176. Two problems
  177. ticking noise
  178. aftermarket headers
  179. HID Ballast,where to buy
  180. MTF question
  181. Which Metric sockets/wrenchs for road trip
  182. front o2sensor
  183. vtech stalling??!!!
  184. p1259 code
  185. Battery died, Now engine shuts off.
  186. DIY timing chain tensioner?
  187. Easy Fix?
  188. 2001 S2000 wont start with good battery
  189. Diff bolt
  190. have you ever seafoam a S?
  191. clutch going out?
  192. Owy
  193. need help
  194. Looking for opinion on Engine Torque Dampers
  195. Test pipe question
  196. Preventing and Repairing holes in top
  197. Cheapest good turbo kit
  198. Give me a break, No don't break!
  199. Homeade intake plate: Lexan>aluminum
  200. Problem: Code - P0113
  201. Finally my clutch arrives.
  202. Boring out the S2000
  203. Help !!!!
  204. will no cat or resanator make your car misfire
  205. Bad News
  206. FS: Used K&N FIPK 2 Short Ram intake
  207. FS: Used 2005 S2000 stock header
  208. invidia dual exhaust
  209. first magor problem
  210. Sticky/Knotchy Clutch
  211. Clutch feeling spongy and loose and not stiff anymore.
  212. mechanical over rev
  213. Ap1 "knock" noise when i go in reverse
  214. HELP! Annoying Whistling Intake
  215. Anyone try to run an EVAC system on a F20/F22?
  216. Gonna replace a gasket
  217. HELP!! please
  218. Engine Code P-1456
  219. don--this is for you -- v8 s2000
  220. CEL light-need advice please
  221. mysterious rear end vibration
  222. INTAKE?
  223. Auto Tensioner chain Can i Re Use it ???!!!
  224. spun #2, is this common
  225. CEL help
  226. ECM question
  227. gas light
  228. Rear End vibration while accellerating???
  229. Checking recalls
  230. CEL P0411
  231. Judder in 2nd gear ???
  232. tranny noise did replace throwout bearing please help!!!!
  233. Which Year is Best?
  234. ap1 vs ap2 transmission
  235. OBD Port Location
  236. The red
  237. THE WORST DAY EVER - ENGINE DEATH
  238. 01 s2000 battery problem question
  239. Difficulty pushing down on shift knob to put into Reverse
  240. Transmission get better after vtec?
  241. test pipe
  242. car wont start
  243. f20 swapped to f22 questions
  244. Help Tranny noise?
  245. Speed limiter
  246. Magnaflow verses invidia exhaust
  247. AEM V2 CAI!
  248. Clutch help
  249. Tranny fluid...
  250. US or UK ECU in Jap Import?
