View Full Version : Engine Tech / Drivetrain
Pages : [1] 2 3 4 5 6 7 8
  1. Bogging on low rpm throttle tip in
  2. Fuel Injector Adapter Connectors
  3. Deciding on K&N Intake
  4. 02 sensor
  5. S2k vs c5 vette
  6. Hitting 300 hp help
  7. Silly Question
  8. Engine Bay Noise at 2900-3000 RPM
  9. Catback exhaust and intake help!
  10. Engine Swap
  11. 5.5 Inch Air Filter
  12. new clutch/flywheel
  13. Rare issue? S.O.S...Help
  14. Problems starting car when cold
  15. Differential worn out?
  16. Weird Clutch Pedal Feel
  17. March Modifications to Rosie
  18. UK Exhaust Mod by King Motorsports
  19. valvoline vr1
  20. Any worth while N/A power to be found
  21. Gear X or Mission gear swap for an AP1 trans
  22. No reverse lockout. TSB has been performed
  23. SRS Module
  24. Okada Projects Plasma Jet Coil Packs
  25. Diff oil weight options
  26. P0498 thrown after winter storage
  27. Ticking sound
  28. this is really starting to annoy me....
  29. Advice needed... oil change interval with very little use.
  30. Engine Rebuild
  31. What's this stub on the exhaust system?
  32. OE?
  33. HELP. s2k will not turn over after rattle while driving
  34. Engine Light
  35. Tranny Fluid Change
  36. ARK Exhaust
  37. 4.78's =)
  38. Clutch kit help
  39. oil smell inside car
  40. screeching noise
  41. CEL + VSC + TCS lights on
  42. Honda S8300 =O
  43. Notchy tranny (get your mind out of the gutter).
  44. Front wheel bearing noise
  45. po302,303,304 cylinder misfire - plugs?
  46. serpentine belt
  47. New Exhaust =D
  48. Vibration under heavy acceleration
  49. Do Not Use E15 Fuel
  50. Exhaust and engine accoustics for asthetics and performance
  51. E15 Fuel, A warning on it's use.
  52. engine swap in California
  53. Repair Manual 2000 - 2003
  54. Magnaflow exhaust question
  55. Opinions needed
  56. What is the difference between shocks ap1 2000 and 04-05 ap2?
  57. Misfire need some help
  58. Just rebuilt engine - no spark to coils
  59. s2000 driveshaft/propeller?
  60. Is this sound shifting bearing races from the axle nut TSB?
  61. A/C compressor or A/C clutch seized?
  62. squeaky/ crackling clutch pedal
  63. cold heat?
  64. battery cable size
  65. invidia n1 single?
  66. Odd sound
  67. I think that I've got a torn outer CV joint boot.
  68. Engine / Trans Bolt Pattern ???
  69. slave cylinder help
  70. Sticky tranny
  71. White smoke only in low RPM's when accelerating
  72. Hi-Idle issue -- where to look
  73. Vibration under hard acceleration problem solved.
  74. Did the timing jump?
  75. Engine Problems
  76. Slight Oil leak_2001 S2K
  77. S2K newby
  78. scraping/clunking from a dead stop
  79. Abs light help.
  80. Engine idle and stumbling issue
  81. headers
  82. ECU Reflash
  83. Unique idle problem
  84. Why no air pump
  85. AP1 ECU vs AP2 ECU in Stock MY04 2.2L w/Test Pipe
  86. Flickering Speedometer
  87. Looking to get a s2000 and turbo it?
  88. Car stalling out
  89. which exhaust(s)
  90. car feels a little sluggish.
  91. V8 swap
  92. Greddy Spectrum Elite
  93. Help vtec oil pressure sensor
  94. opinion
  95. 2009 Service Manual (2nd edition) Where to find?
  96. clutch working BACKWARDS!? WTF!?
  97. AP2 leaking water
  98. Oil Consumption/Additive
  99. ecm question
  100. Is my clutch worn out?
  101. f20c in ae71 corolla problems. HELP!!
  102. need help!!!
  103. P2195 code still!
  104. Insanely embarrassing question
  105. best clutch for heel&toeing or rev matchings
  106. Engine problem... PLEASE help!!!
  107. Oil Additive/ Slick50
  108. Vibration/rattle at low rpms
  109. Does anyone else have this clack from their engine
  110. Soft Clutch
  111. Invidia Q300
  112. Changing the transmission fluid
  113. Smoking Issue
  114. Anyone identify this exhaust?
  115. 2001 AP1 S2000
  116. Fuel Gauge going all weird
  117. problems on fresh rebuilt engine.....
  118. weird feeling going into gear
  119. Slight oil smell at stop light
  120. bogging out/idle
  121. clutch lost pressure (just halfway)
  122. Timing chain tensioner
  123. Mase Engineering, Great Tuner
  124. How To Get More Sound From A Stock Exhaust
  125. Will running e85 hurt my motor?
  126. as if the gearbox wasn't good enough...
  127. The Puffo-intake is now for sale
  128. Which Red Line do you use in differential and which in transmission?
  129. Resonator delete!
  130. Weapon R vs K&N Air Intake
  131. Best online price for oil filter
  132. "Clicking" noise on starting roll/turns/reverse
  133. OIL CATCH CAN/KRANK VENTS QUESTON PLS HELP!:)
  134. Catalytic Converter O2 sensor price differences
  135. Computer Chip HP boost?
  136. oil leak and...
  137. drivetrain loading problem
  138. HELLLLPPPP!!! tranny issue
  139. Waterless Coolant
  140. Oil Pressure Numbers at 110K miles
  141. More HP and TQ
  142. OIl change coming up. Have questions.
  143. Is changing your oil often a bad thing?
  144. CEL with test pipe
  145. Intermittent issue. HELLp.!
  146. Block Needed AP1
  147. How many Timing Chain Tensioners have you gone thru???!!!
  148. Clutch pressure
  149. yur opinion plz
  150. Beating a Horse here..Cooling plate
  151. Arrrrrrghhh!!!
  152. Look what I got today!
  153. Will AP1 Differential work on AP2
  154. HP gains with Skunk2 Megapower Exhaust
  155. transmission removal and installation
  156. HondaCare Warranty
  157. Engine cutting out just before Vtec kicks in
  158. Broken spark plug
  159. Anybody Have a spare Knock sensor
  160. supercharged s2k
  161. f22 retainers/springs/base??
  162. Belt tensioner
  163. How much for a head/Valve gasket job??
  164. 'Iss'un from S2Klassie
  165. anyone using aftermarket engine mounts?
  166. Air Filter
  167. Advice for S2000 parked for several months
  168. NGK 7173
  169. Charge S2000
  170. ap1 slave cylinder in ap2
  171. yet another discussion about changing oil
  172. Tech question
  173. New hoses during coolant change
  174. Final gear swap Flat rate
  175. how much oil do you consume?
  176. stripped spark plug cover screw
  177. invidia q300 single exhaust
  178. good performance mods for under $1000
  179. Best hp mods?? N/a
  180. LEDs to get a developing financial system
  181. Aftermarket Radiator
  182. Radiator Hoses
  183. Cam follower / rocker arm needed asap
  184. I did a coolant drain and refill. Now I have no heat.
  185. Science of Speed
  186. Bypass Control Solenoid Breather Missing
  187. Vsa and check engine light after storage
  188. Aem fuel rail question
  189. How to know when diff is crapping out.
  190. CEL LOW COMPRESSION
  191. Top Speed Pro 1 exzaust
  192. Map sensor reading too high, overfueling
  193. some metal found while oil change.
  194. O2 Sensor Question
  195. Stage 2 Clutch, bad slave cylinder?
  196. slave cylinder problems
  197. Spark plugs
  198. Update on Notchy Tranny
  199. Air pump doesn't turn on when it's cold...
  200. All 4 cylinders misfiring... Only when hot
  201. clutch pedal went all the way down...
  202. Open connectors and an open vacuum hose
  203. Engine ticking (not TCT) noise. Valve noise? rod knock?
  204. Help Guys
  205. CamShaft holder Repair / Replace
  206. clutch squeaks when depressing
  207. Need clutch help.
  208. Buying new clutch suggestions?
  209. Going to have a heart attack... Can't figure it out. I have done research
  210. Valve job done...Oil pump Goes out related?
  211. Stiff/Notchy Clutch
  212. CEL
  213. Catalytic Converter
  214. 2001 vs 2002 spring/damper differences?
  215. Valve Job
  216. Best brake fluid?
  217. Need a new clutch $1500 quote?
  218. Clutch rattle or throwout bearing going bad?
  219. hood dampers
  220. best carb legal exhaust setup(header,hfc, exhaust)for a supercharged car
  221. Noise Question
  222. Air Pump??
  223. Looking to add cold air intake & exhaust
  224. Stock too cold Air and Cat back. Do i need a tune?
  225. please help connector c101 pinout ap2 06
  226. Test Pipe Question
  227. Changing my ap1 clutch
  228. hi guys, im new to the forum. looking for carb legal stuff
  229. Clutch Pedal way too soft, rough shifting
  230. fuel rail tap for sender?
  231. question about fluid changes.
  232. engine help
  233. Put an Invidia N1 exhaust on my '08.
  234. Engine Install
  235. New Shoes! and WT$%#&!
  236. AP1, which gears are best?
  237. Power house Amuse
  238. My car takes forever to pick up
  239. Clicking / knocking from rear or underneath - w/ video example
  240. Aftermarket engine controller
  241. Help, Rear left wheel rubbing
  242. Radiator Issue
  243. Question! If I Build my motor, can my block handle the high RPM's???
  244. Stock Air Box a Restriction ?
  245. How to tell when your air cleaner is dirty
  246. clutch HELP
  247. Cat Power
  248. misfire cylinder #2
  249. I over revved my s2000..
  250. Sheered valve cover bolt
