- Bad Speaker?
- Window Problem!
- A/C vent/cup holder/seat mount for GPS/Tablet
- Rattle Finally Gone!
- Dash kit?
- Heeeeelp! It's hot and my top won't go down.
- Trunk carpet clips?
- Component Speaker Upgrade 4 cheap
- Red shift boot that matches red AP2 interior
- Switchblade key
- Window stuck down!
- S2000 INTERIOR UPGRADES? HELP PLEASE!!
- 12V DC output dead then my stereo stopped
- Radio has CD player, wont accept CD
- GPS units,Iphone, android,tomtom, Garmin, papermap
- Swapping seat covers
- Carpet Removal/Replacement
- S2000 Stereo Install - Lots of Pics and Vids!!!
- Does anyone here own a set of Sparco R100's?
- adding new speakers
- Please help! SRS code no signal with passenger weight sensors?
- cruise control yay
- Replacement Mats
- Stereo upgrade with iPhone integration and Steering wheel controls
- S2000 OEM JDM Navigation Bezel, Navi Trim
- How to extend the range of your remote transmitter
- ECU output to dashboard - temperature.
- Need Help! 2007 vs 2008 s2k cluster harness difference??
- Black Box Dash cam coming.
- quick question on amp placement
- Advice requested for "plug and play" speakers
- Issues with heat 02 s2k.
- Strange key remote issue.
- Ballasts corroded need advice
- 2007 s2000 red interior with all black seats?
- Help AP1 Halo Headlights
- My S2000 woes, £2k spent, still not fixed :(
- ap2 center console spring
- Quick Question
- Seat Help
- tail lights wont turn off
- AP1 a/c lights on. no fan or compressor
- Don't know what you got...
- Factory Audio Help/ iPod connection 08-09
- Putting the wind blocker down.
- New seats, will they work?
- Has anyone heard from JS2K?
- Will replacing turn signal bulbs with LED bulbs cause the directionals to blink fast.
- Dome light help please!
- quick question plastic latch
- Replacing the Tachometer and Speedometer?
- Will AP2 steering wheel fit my AP1?
- Faux chrome removal
- Audio Help
- just bought my s2000 alarm problem
- Driver Window only lowers partially when Top Lowered
- Recording and visibility toys
- electrical system education....
- Trunk Light Doesn't Work!
- JVC KD-NX5000
- Sub inclosure and amp rack
- Seat covers
- Voltage issues... Ideas?
- Radio
- I have to replace lower seat cushion.
- rear light mod ?
- switching DCI kill radio??
- How to replace front parking light? (pic inside)
- Got my Alpine.
- Modifry convertible straps
- Hard wire my V1?
- Headlight :(
- cruise control lamp
- radar detector?
- Can't start SRS procedure with paper clips
- Replacing the Center console for ap1
- fuse box help - (Pics included)
- Advice
- Can anybody here ascertain the part # for
- Need interior leather! Help!!
- After market CD player
- Radio dead, no prompt for code
- How to: Wire cruise control buttons with an aftermarket steering wheel
- wink mirror in s2000?
- Interior Light Problems
- Battery dead. Lesson learned
- "14 PIN CONNECTOR QUESTION"
- Center cap on steering wheel...
- I have an intermittent front parking light.
- Honda Music Link 2.0 Question
- Locked out of my radio. (Help)
- Long Antenna?
- Alpine CDE-126
- "XM" Radio Question
- What's going on here?
- Inner window felt now rubbing up against the window? Weird problem v.vid
- Need help w/ clutch slave cylinder leaking?
- Rear tweeter mount idea
- Seats and Harnesses
- S2K 4 point harness
- 6 speed shift knobs?
- Headlight Repair or replacement?
- 2007 AP2 low beam bulbs.
- seat belt replacement
- A/C Climate Control Light
- Yaaay remote start!!!
- Does your speedo and tacho blink?
- Alpine loose faceplate trim in S2000 - Install Question
- Seat Options?
- Need some help. Anybody have this problem?
- speaker upgrade
- Is there something missing?
- Help with fusebox - stereo died?
- Interior plastic
- in car screen?
- Last 3 bars on fuel guage
- Need some info on hazard/turn relay
- CD stuck in factory CD player
- Secret Compartment, Fuel Door and now...
- JL AUDIO C2650X
- sub woofer solution
- LED Bulbs are they worth it?
- KENWOOD KIV-BT901: WOW
- looking to put lights in my car.
- Totally confused - Steering Wheel Decals
- Just ordered new HU!
- Garnish cover
- I`m Gettin Old
- Instrument Panel
- S2000 Leather - normally stiff?
- CR shift knob w/ red numbers
- What kind of speakers?
- Free Shift Boot / Ebrake boot / Console (NEED PICS)
- faded interior
- Tan interiors
- Problem with Alpine, Audiovox, Modifry install
- Alpine IDA-X305s install
- Installed CR Shift knob (yellow numbers)
- Changed soft top strikers!
- HELP: Ap1 Cluster just jumped from 114k miles to 188k?
- Compatible Head Unit?
- passenger window not working
- 100amp fuse?
- best audio system to bump that music
- XM making regular clicking sound
- Rear view
- What size are my speakers
- 2005 seats into a 2002
- Switched Source
- Problem with Speakers. please help
- Who's HORN-eee??
- Wideband install
- S2000 Preferred Head Unit and Wattage
- Escort 9500ix Mirror Mount
- Corner light is out
- so, i pulled a Dez...
- Pump it up!
- S2000CR OEM seats
- I want one
- Whats the gadget???
- MB Quart Premium PVI216 6.5" 2-Way Components install issue
- A bunch of AP2 console questions... I need help for a flawless conversion!
- stereo amp questions
- Help aftermarket alarm =(
- Aftermarket head unit installation kit?
- odd request
- OCD about "the carpet matching the drapes"
- New head and speakers???
- new 'media receiver' deck question
- HELP!!
- Glove box removal
- Adjusting headlights
- OEM Head Unit with amplifier
- Soft top and both windows will not go up.
- center console removal
- 2007 Airbag Sensors
- Using oem xm antenna with aftermarket hu
- Roll Hoop Trim Split Apart
- How difficult to fix this?
- limiter
- Interior reinstall issues after Dynamat install?
- I think its time for some air horns....
- Traffic light prism
- Interior Lights Quit
- Screw Clip?
- DRL Nightmare
- need help with new seats
- Seat lock question.
- AUX INPUT ??
- fd2 knob - *pics*
- dead radio...need help
- small uh oh...
- NRG quick release steering wheel?
- New System
- Experience: CDA-117 and MM6501
- cr knob..
- Playin with knobs!
- remote
- I want to buy an s2000 want to know if i will fit
- Tiny Key hole?
- How Do I remove the Stereo Dust cover?
- wtf is shin-etsu
- tri-pod A-pillar Please help me find one!
- S2000 2006+ CLUSTER COOLANT SIGNAL
- Bose automotive
- Airbag On/Off Switch Installation (passenger)
- Looking for advice on some good speakers
- Radio door nonsense
- Best sounding s2k evah.
- help! radio door is stuck
- Stereo stuff
- Water in floorboard
- Couple questions about factory alarm
- Darn battery died over the winter....
- USA SPEC ipod interface review
- FOB Lighting Problem
- Rear Speaker Advice (not S-Pods) Needed
- Black seats in my 01 red interior?
- Va-jay-jay
- COLOR CODE RED INTERIOR
- Hard wire new cigarette lighter power port? Where?
- 8 Cd changer on my 05
- Weird sound from convertible top
- Upgrading my stereo system, need help.
- Mounting Depth on S2k?
- Antenna next to the trunk
- Speedo Color
- noob battery question
- Help parking lights stay on
- finally decided on audio setup..opinions wanted
- CD player... Seriously???
- Think this speaker will fit in the S?
- cup holder button stuck
- Sony DSX-S300BTX
- D/S Window dosent one touch down.
- Need Advice on Audio
- Boston Acoustics S65RC OEM speaker replacement, review
- Stuck shift knob ?
- Full install tomorrow! YAY!
- Speed signal lead for navigation?
- What are the + and - buttons on the left side of the gauge cluster?
- Is it hard to get the radio code from a dealer if it's not the original radio?
- Blue Interior Lights. How to?
- Please help me! Trying to repair interior.
- Passport 9500ci custom install
- Whats the best New radio for 2000 S2000?
- 02 oem radio
- Ac always on!!
- Wiggity-Wacked-Out Gas Gauge
- Keyless entry/alarm not working
