Old 11-06-2009, 07:50 PM   #1 (permalink)
chazdawg35
chazdawg35's Avatar
Dash Lights Flickering?
Hey Dudes and Dudettes, more problems tonight I was coming home from work and the dash lights started dimming out. Not completely off but at idle the RPM and speedo would start to flicker but if I was to do more than 900rpm at a stand still and driving they are fine! Checked the Alternator and it's at 13.9v , any idea's? Thanks Chaz
Old 11-06-2009, 08:07 PM   #2 (permalink)
nico
nico's Avatar
maybe a bad connection, Chaz check your fuses see if any of them are hot they get hot when they are dirty and have a poor connection. just something to check,
nico is offline   Reply With Quote
Old 11-06-2009, 08:29 PM   #3 (permalink)
nico
nico's Avatar
turn the lights on and move the wires under your dash see if there is a flicker of your dash lights try to isolate the wires that affect the dash lights and look for a bad connection.
Old 11-06-2009, 09:38 PM   #4 (permalink)
TheSoundMan21
Village Pyro
TheSoundMan21's Avatar
mine does the exact same thing... I got an 02 with 100k on the clock.
yO vTeCh wAs WiGgItY WaCk yO!
best quote by GO.
Old 11-06-2009, 10:30 PM   #5 (permalink)
flyingarmadillo
flyingarmadillo's Avatar
See if replacing the fuse to the dash lights fixes it. I haven't had my S long enough for there to be a problem but everything else I've owned has had fuses go bad - they don't blow, they just make an intermittent connection.
Old 11-06-2009, 10:40 PM   #6 (permalink)
TheSoundMan21
Village Pyro
alright Ill give that a shot tomorrow first chance I get.
best quote by GO.
Old 11-06-2009, 11:52 PM   #7 (permalink)
JDMHonda
RedAt8
JDMHonda's Avatar
What is this Chaz? Whats with all the problems?
Old 11-07-2009, 06:54 AM   #8 (permalink)
TheSoundMan21
Village Pyro
Its them damn gremlins
best quote by GO.
Old 11-07-2009, 10:45 AM   #9 (permalink)
chazdawg35
chazdawg35's Avatar
I'll try the fuse first when I go back to work I'll check Alldata to see if there are any fixes. Thanks everybody'
Old 11-07-2009, 11:16 AM   #10 (permalink)
Where did you measure the 13.9 V? If it was at the battery then you might be surprised to know there is a voltage drop of nearly a volt at the inside fuse box. I am planning on running a wire from the secondary fuse box under hood to power my SPA gauges and eliminate this condition.
Old 11-07-2009, 10:55 PM   #11 (permalink)
philiam
Does it turn over OK?
Old 11-08-2009, 09:30 AM   #12 (permalink)
lonestarbuzz
lonestarbuzz's Avatar
are you drawing power with anything else like an amp or powered sub?
Old 11-08-2009, 11:24 AM   #13 (permalink)
chazdawg35
chazdawg35's Avatar
I'm running everything stock EXCEPT an AFC Neo controller that is powered by the aux fuse spot. It is mostly for the face light, one thing is that the dome light doesn't work either.
Old 11-08-2009, 03:18 PM   #14 (permalink)
check the fuse, it fuse #24 in the under dash fuse box.
Old 11-18-2009, 08:47 PM   #15 (permalink)
chazdawg35
chazdawg35's Avatar
Well the fuse is good and no TSB on Alldata anymore idea's?
Old 11-18-2009, 10:01 PM   #16 (permalink)
J'sS2K
J'sS2K's Avatar
mine does that too. sometimes, my RPM would drop to around 100 and get back to normal. i thought it was going to die everytime it did that. wierd stuff man!!!
www.getgopod.com
flickering, lights
