Old 11-17-2009, 06:25 AM   #1 (permalink)
cans2k
VSS location for Navi install, help please!
Hi everyone. I've been a member since March, but this is my first post.
I have a 2005 S2K and I just purchased a JVC KD-NX5000 single DIN navigation unit and will be installing it soon.
My question is, where is the VSS location on the ECM? I need to tap into this for the navigation to work correctly.
Thanks in advance!
cans2k is offline   Reply With Quote
Old 11-17-2009, 01:19 PM   #2 (permalink)
cans2k
Has anyone installed a navi system in their s2k?
Old 11-17-2009, 01:44 PM   #3 (permalink)
turbosix
http://www.honda-tech.com/showthread.php?t=1570344
some info there should be helpful,mang.
turbosix.net
turbosix is online now   Reply With Quote
Old 11-17-2009, 10:44 PM   #4 (permalink)
Raconteur
You might want to ask this on S2kca.com. Look for the Xviper (or repiv) s2000 thread. If anyone can tell you where to look, it's Dave. (but why do you have to tap into anything? Isn't this a stand-alone unit?)
Old 11-18-2009, 05:37 AM   #5 (permalink)
cans2k
It is replacing the factory head unit and needs to tap into the vss for proper navi function. This is not uncommon for most in-dash navi units. I've owned 2 other Pioneer units that required the same thing.
Old 11-19-2009, 12:12 PM   #6 (permalink)
cans2k
This is basically what I am looking for, except for the AP2...
Old 11-19-2009, 04:09 PM   #7 (permalink)
Raconteur
The variable speed sensor is the black and white wire on the passenger side behind the kick panel. Go to modifry.com and find the plug and play adapter for the Pioneer H/U. Bob shows you how to hook this up.
Old 11-19-2009, 07:55 PM   #8 (permalink)
cans2k
Really appreciate the help kgf! Thanks!
din, install, jvc, kd, location, nav, navi, navigation, nx5000, put, s2000, s2k, sensor, speedometer, stand, unit, vss
« headlight out | VSC »
