Register Forgot Password?
Search
Welcome to the S2000 Forums.
Old 03-19-2011, 08:45 AM   #1 (permalink)
S2k Noob.
BradWorld's Avatar
Hard wire new cigarette lighter power port? Where?
Hey all. I need to know where is the best place to patch in an additional cig lighter/power port under the dash.
I am leaving my stock radio as is for now on my 2005 S2k. I added a Sirius receiver under the dash on the passenger side. It works great. I have intially been using the FM modulator, which is okay, but not great. So I have purchased the Blitz AUX-in interface, which is now half way installed. If figured while I am there, I will hard wire the power as well, so I can free up my regular cig lighter power port for my cell phone charger, etc.
So it appears that with these new Sirius radios, they have this "Power Connect" feature, where there is some technology in the power plug. I dont know if I need it or not, but Sirius recommends to use it, and the installers I talked to said that they just hard wire in another cigarette lighter power port under the dash for the sirius. I am okay with this. I have purchased the required hard wire cig lighter power port kit.
So the question is, where is the best place to tap into for the hot and the ground? I want to use the quick splice connectors if possible. And I dont want to take apart any more of my dash than I have to. My radio is half way out right now, so I have access to whatever is behind there for the next couple of hours.
Thanks in advance for your help.
BradWorld is offline   Reply With Quote
Old 03-19-2011, 09:24 AM   #2 (permalink)
TTMartin's Avatar
The fuse block has extra taps so you don't need to splice any wires.
Click the image to open in full size.
Ground can be added to the bolt for the hood release.
Tom
TTMartin is offline   Reply With Quote
Old 03-19-2011, 11:55 AM   #3 (permalink)
S2k Noob.
BradWorld's Avatar
Cool. Thanks. Now I just have to find the fuse block.
Any good grounding spots on the passenger side or behind the radio?
Old 03-25-2011, 08:02 PM   #4 (permalink)
zooyork1319's Avatar
i wired an additional cig lighter in my secret compartment so my phone could charge and be out of the way i just ran wires from the stock cig lighter
Theres nothing like going for a drive top down in the s2k.
zooyork1319 is offline   Reply With Quote
Old 03-25-2011, 11:27 PM   #5 (permalink)
L8Apex's Avatar
I used the constant supply to feed these two sockets mounted into the lower dasy panel to be able to have short feeds to my Nuvi 1390T and Cell Phone.
old, rude, grumpy track junkie
Red & Tan Fan
L8Apex is online now   Reply With Quote
Old 03-26-2011, 05:27 AM   #6 (permalink)
S2k Noob.
BradWorld's Avatar
Thanks guys, those are great ideas. I ended up buying a whole new stereo head unit. After installing the Aux-in adapter, I realized how easy it was to replace the head unit. So I purchased a new JVC system with front and rear Aux inputs, as well as a USB controller for the iPod and thumb drives. I am glad I did. It sounds much better. And provides much needed functionlity that I have in my other vehicles, such as playing MP3 CD's, etc.
I wired the new cig socket into the wiring harness I made for the new stereo, which worked out really great. I plugged my Satellite reciever's power adapter into the new cig socket, taped it up with electrical tape, and tucked it up under the dash. I now have a great clean install.
Thanks for the tips!
S2000
Honda S2000
Paid Advertisement
auxiliary, cig, cigarette, connector, dash, free, hardwire, lighter, mount, mounted, power, s2000, sirius, socket, tips, wire
Search this Thread:
Advanced Search
