Register Forgot Password?
Welcome to the S2000 Forums.
submit to reddit
Old 06-22-2011, 10:42 PM   #1 (permalink)
smohan123's Avatar
Send a message via AIM to smohan123
A bunch of AP2 console questions... I need help for a flawless conversion!
Hey guys, I recently purchased an AP2 console for my MY03 S2000, and I'm looking to get the console back to tip-top shape before installing it. I am having trouble getting the sliding door to close once it is opened. The sliding motion itself is relatively unencumbered, but the locking process does not work as desired. When I slide the cupholder door against the locking mechanism, the small plastic protrusion that is normally held by the button's latch will not seat at all. It looks like the cupholder door release button raises too high in its socket and does not allow the aforementioned protrusion to slide up the angled latch. Is there a good way to adjust the button or is something fundamentally wrong with the unit? As is, I can get the door to latch, but only if I simultaneously push the release button partially down while sliding the door into place and then releasing the button. Obviously, this isn't ideal.
Also, there appears to be a small amount of yellow spray paint on the plastic part of the console. Is there a good way to remove spray paint from this kind of plastic?
Lastly, what is the material used for the MY03 shift boot (I have an AP1 console from which I might harvest the shift boot) and the MY04-05 shift boot? Are either of them leather or both vinyl? I might want to recover the elbow pad with some JPM Coachworks leather or alcantara. What is the best method of padding the armrest? Can I ask them to pad it in addition to installing?
Thanks in advance.
smohan123 is offline   Reply With Quote
Old 06-23-2011, 07:39 AM   #2 (permalink)
phins2rt's Avatar
JPM will add padding if you request it and will do the install if you send them your armrest. It is a pretty easy DIY, though.
02 S2000 Berlina Black/Black
08 Acura MDX
03 Acura MDX
99 Acura RL
phins2rt is offline   Reply With Quote
Old 06-23-2011, 08:39 AM   #3 (permalink)
Dismember
StrayS2k's Avatar
Can't answer your questions but thought I would pass along this DIY...
http://www.s2ki.com/s2000/topic/1651...sole-on-00-03/
Good luck and post pics when all is done!
StrayS2k is offline   Reply With Quote
Old 06-23-2011, 11:00 AM   #4 (permalink)
smohan123's Avatar
That's a great howto. Thanks a bunch. I had been looking at another one, but this is just EXACTLY what I need to do. Unfortunately, I am still buggered about the cupholder door. Can anyone help?
Old 06-25-2011, 02:58 PM   #5 (permalink)
smohan123's Avatar
Guys, I'd love to be able to fix this thing up to install tomorrow. I'm sorry to be a bumping freak, but if anyone has some insight into how to adjust the latch, I'd greatly appreciate it. Here are some pictures. Sorry if they're massive, I couldn't scale it without losing a tremendous amount of image clarity.
Old 06-25-2011, 08:38 PM   #6 (permalink)
I don't understand why some ap2 center counsels are all black then some ar silver
wagsS2000 is offline   Reply With Quote
Old 07-05-2011, 02:58 AM   #7 (permalink)
smohan123's Avatar
Can anyone help?
Old 07-05-2011, 03:03 AM   #8 (permalink)
Grover's Dad.
Because Honda changed the console color in later cars. The 04's had silver, my 08 has a carbon fiber pattern...enough people complained about reflections from the silver cover they changed it.
The Gettysburg Get Together III. It's back and even better. Aug 3-5. See you in Gettysburg.
_____________________________
Spring Fling '12 - Antietam
- More battlefields, more S2000's, more friends. May 18-20, 2012 (Details here)
2008 ABP CR #400 of 699
Old 07-05-2011, 03:04 AM   #9 (permalink)
Grover's Dad.
Originally Posted by smohan123 View Post
Can anyone help?
I don't believe there's really a way to adjust the latch. If anything, probably the only thing you can change is the guide rails for the cover.
Old 07-05-2011, 03:09 AM   #10 (permalink)
smohan123's Avatar
Might replacing the latch help?
edit: Is that even possible?
Old 07-05-2011, 04:49 AM   #11 (permalink)
Grover's Dad.
I can't get to the site from work but go to www.hondaautomotiveparts.com and use the parts finder. You should be able to find a parts breakdown which will show you the parts available. That might give you an idea of what can be changed.
Old 02-04-2012, 11:33 AM   #12 (permalink)
BBD324's Avatar
THanks for the DIY link. Thats really helpful!
BBD324 is offline   Reply With Quote
S2000
Honda S2000
Paid Advertisement
submit to reddit
alcantara, ap, ap1, ap2, center, change, console, conversion, cup, holder, honda, jpm, leather, lock, removal, s2000, shiftboot
Search this Thread:
Advanced Search
Contact Us - S2000 Forums - Archive - Top
X vBulletin 3.8.7 Debug Information
  • Page Generation 0.19342 seconds
  • Memory Usage 5,750KB
  • Queries Executed 8 (?)
More Information
Template Usage:
  • (1)SHOWTHREAD
  • (1)ad_footer_end
  • (1)ad_footer_start
  • (1)ad_header_end
  • (1)ad_header_logo
  • (1)ad_navbar_below
  • (1)ad_showthread_beforeqr
  • (1)ad_showthread_firstpost
  • (1)ad_showthread_firstpost_sig
  • (1)ad_showthread_firstpost_start
  • (1)album_all_navbar_link
  • (1)album_all_quick_links
  • (4)bbcode_quote
  • (1)footer
  • (1)forumrules
  • (1)gobutton
  • (1)header
  • (1)headinclude
  • (5)im_aim
  • (1)navbar
  • (3)navbar_link
  • (1)navbar_links_loginbox
  • (3)option
  • (12)postbit_legacy
  • (12)postbit_onlinestatus
  • (12)postbit_wrapper
  • (1)social_thread_share_headinclude
  • (1)spacer_close
  • (1)spacer_open
  • (1)style_analytics_tracker
  • (17)tagbit
  • (1)tagbit_wrapper
  • (1)vbnexus_buttons
  • (1)vbseo_linkbackmenu
  • (1)vbseo_linkbackmenu_entry
Phrase Groups Available:
  • global
  • inlinemod
  • postbit
  • posting
  • reputationlevel
  • showthread
  • vbnexus
Included Files:
  • .//var/ibvbshare/vbseo/3.5.2/vbseo.php
  • .//var/ibvbshare/vbseo/3.5.2/vbseo/includes/functions_vbseo.php
  • .//var/ibvbshare/vbseo/3.5.2/vbseo/includes/functions_vbseo_pre.php
  • .//var/ibvbshare/vbseo/3.5.2/vbseo/includes/functions_vbseo_url.php
  • .//var/ibvbshare/vbseo/3.5.2/vbseo/includes/functions_vbseo_createurl.php
  • .//var/ibvbshare/vbseo/3.5.2/vbseo/includes/functions_vbseo_db.php
  • .//var/ibvbshare/vbseo/3.5.2/vbseo/includes/functions_vbseo_vb.php
  • .//var/ibvbshare/vbseo/3.5.2/vbseo/includes/functions_vbseo_seo.php
  • .//var/ibvbshare/vbseo/3.5.2/vbseo/includes/functions_vbseo_misc.php
  • .//var/ibvbshare/vbseo/3.5.2/vbseo/includes/functions_vbseo_crr.php
  • .//var/ibvbshare/vbseo/3.5.2/vbseo/includes/functions_vbseo_cache.php
  • .//var/ibvbshare/vbseo/3.5.2/vbseo/includes/functions_vbseo_hook.php
  • .//var/ibvbshare/vbseo/3.5.2/vbseo/includes/functions_vbseo_startup.php
  • ./includes/config.php
  • ./showthread.php
  • ./global.php
  • ./includes/init.php
  • ./includes/class_core.php
  • ./includes/functions.php
  • ./includes/class_hook.php
  • .//var/ibvbshare/vbnexus4.1.5/vBNexus.php
  • .//var/ibvbshare/vbnexus4.1.5/vBNexus_fb.php
  • .//var/ibvbshare/vbnexus4.1.5/vBNexus_user.php
  • ./includes/functions_login.php
  • .//var/ibvbshare/vbnexus4.1.5/facebook-php-sdk/facebook.php
  • .//var/ibvbshare/vbnexus4.1.5/facebook-php-sdk/base_facebook.php
  • .//var/ibvbshare/vbnexus4.1.5/vBNexus_gfc.php
  • ./includes/functions_album.php
  • .//var/ibvbshare/autocomm_master/jquery.php
  • ./includes/functions_bigthree.php
  • ./includes/class_postbit.php
  • ./includes/class_bbcode.php
  • ./includes/functions_reputation.php
Hooks Called:
  • init_startup
  • cache_permissions
  • fetch_threadinfo_query
  • fetch_threadinfo
  • fetch_foruminfo
  • style_fetch
  • cache_templates
  • global_start
  • parse_templates
  • global_setup_complete
  • showthread_start
  • showthread_getinfo
  • showthread_post_start
  • showthread_query_postids
  • showthread_query
  • bbcode_fetch_tags
  • bbcode_create
  • showthread_postbit_create
  • postbit_factory
  • postbit_display_start
  • fetch_musername
  • postbit_imicons
  • bbcode_parse_start
  • bbcode_parse_complete_precache
  • postbit_display_complete
  • tag_fetchbit
  • tag_fetchbit_complete
  • forumrules
  • navbits
  • navbits_complete
  • showthread_complete
