Old 01-16-2007, 05:20 PM   #1 (permalink)
S2K Brett
Question sub installation?
I just got new speakers, an amp, and a subwoofer for my black 2002 S2000.
Anybody got any ideas on how to fit a 12" subwoofer into my car? I was thinking maybe where the spare tire is currently located.
S2K Brett is offline   Reply With Quote
Old 01-16-2007, 05:37 PM   #2 (permalink)
Scott
Scott's Avatar
I've got mine put in the spare tire location. It's not a 12", but it fits nicely. Only problem is figuring out what to do with the spare, as it's not a great idea to travel far without one.
The other option is in the trunk. There is the recessed area where the scissor jack and tools go. You can pull that out and make a nice enclosure that fits perfectly flush in there. Every once in awhile, pre-made boxes in that style pop up on ebay.
1966 Ford Mustang
2003 Land Rover Freelander
Old 01-16-2007, 05:48 PM   #3 (permalink)
here is a sub box that I made before its filled or painted
Old 01-16-2007, 09:11 PM   #4 (permalink)
bladerunner
bladerunner's Avatar
I have a 10" diamond audio D3 where my tools were (the installer said a 12" would fit but it really comes down to music preference so if you listen to a lot of rap, techno or other thick beated music get the 12" which can produce lower frequencies and has a lazier performance, if you listen to more of the rock/pop style then go with something that will have faster transitional response to different frequencies like a 10" or less, the 10''s have less mass to move around and can keep up with faster music better than a larger could) capped with a carpeted fibreglass lid and you'd never know what was under there...til you feel it! Stuck the tools under the passenger seat. Powered by 300 rms watts, from 2 channels of my 4 channel Alpine PDX 4.150 amplifier. With the other 300 rms watts divided between my Diamond Audio D6 components, which are housed in Dynamated doors. CD's play on my ALPINE CDA-9857 (maintains use of the "steering wheel" controls), and has a direct connect for my MP3 player with a wire with a minijack running up through my center console through a small drilled hole, so I can slide that cover shut and my MP3 player is non existent. The system is tuned for tight, responsive, clean sound and it delivers. I have a few pics up in my bladerunner member gallery.
Auto Essentials in Thousand Oaks did all of the fabrication and installation. When they did my friends 2004 Corvette Z06, I knew that's where I wanted to go.
Old 01-16-2007, 09:46 PM   #5 (permalink)
hehehe old school ways of thinking are great. I have a 15" sub that could change your mind about the whole 10" sub thing. Its all in the box design. By the way I was just using that pos cv to make sure i had clearance with the hinge.
I currently run mb quart premium comps up front my hu is a jvc whcih im very impressed with for it being a jvc amp is a hifonics with rear channels bridged for the sub and the sub is a pg
Old 08-22-2009, 12:25 PM   #6 (permalink)
jmsutton
go on ebay, i just bought a box already built for the whole were the spare tire tools go for 50.00. Great Price, hope this helps.
jmsutton is offline   Reply With Quote
Old 08-22-2009, 12:46 PM   #7 (permalink)
wow talk about old threads. That was a pimp box I made ashame I trashed it.
2001 Vortech SC
12.8 at 111 miles per hour
Old 08-22-2009, 12:51 PM   #8 (permalink)
You need to find out the correct volume of the box your speaker requires and then make a decision on where to put it. If you remove your spare tire, get a can of flat fix as a substitute.
15, 2004, amp, box, custom, drawing, enclosures, honda, hooking, install, installation, mustang, s2000, seat, subs, subwoofer
K&N FIPK installation question preilly44 Engine Tech / Drivetrain 1 04-05-2007 10:40 PM
Installation instructions for side strakes tien2cool Exterior / Detailing / Body Work 0 01-26-2007 07:16 PM
2006 Hardtop - cost including installation? solid_performer All Other Honda S2000 Related Discussions 1 02-05-2006 09:52 PM
Mugen Air Cleaner & Box Installation Instructions Gookusmaximus All Other Honda S2000 Related Discussions 1 06-16-2005 06:16 PM
Hardtop installation kit pr19842 All Other Honda S2000 Related Discussions 2 10-28-2003 04:43 AM
