Old 03-21-2007, 04:06 PM   #1 (permalink)
wkowens1027
wkowens1027's Avatar
CD Changer
I just installed the CD Changer in the storage compartment between the seats. The ride is so firm that it skips over big bumps. Any solutions? Thanks
wkowens1027 is offline   Reply With Quote
Old 03-21-2007, 04:12 PM   #2 (permalink)
bjurasz
You got one to fit there? You're skipping problem is why I'm glad I use an iPod instead. Aside from switching to an iPod I think your only solution is to not have the unit solidly mounted to the car's body/chassis.
Old 03-21-2007, 04:39 PM   #3 (permalink)
Well, wk, I think you jus' discovered why they didn't use that space for the factory unit.
Old 03-21-2007, 06:11 PM   #4 (permalink)
The factory units are placed in the trunk in the horizontal (flat) position, not sideways. That may be your problem. I have a S2K CD changer in my Insight and it sits facing up. It will skip when I hit a bump, but I don't listen to discs all that often any more with Sirius in the car.
Old 03-21-2007, 10:20 PM   #5 (permalink)
Scooterboy
Either the trunk or hidden glove box are listed as suitable places for the CD changer. Did you use the OEM mounting hardware to mount the changer?
Scooterboy is offline   Reply With Quote
Old 03-22-2007, 11:55 AM   #6 (permalink)
wkowens1027
Yes, I used factory equip. It installed very easy. the hardest part was running the wiring harness from the front to the back, for the XM. Thanks for all the comments.
2008, cd, changer, harness, honda, installation, instructions, oem, s2000, wiring
03 CD changer in 04 model? mdr231 All Other Honda S2000 Related Discussions 2 02-28-2008 04:23 PM
Ipod connectivity w/ cd changer asianmatrix02 Interior / Audio / Electronics 2 02-06-2008 11:55 AM
CD changer? tullymars Interior / Audio / Electronics 6 02-21-2007 06:16 PM
I need to know if a CD changer will work HELL_ON_WHEELS Interior / Audio / Electronics 0 12-27-2006 03:12 PM
CD Changer options for '04 S2K? mdr231 All Other Honda S2000 Related Discussions 1 09-09-2004 02:59 AM
