Old 03-26-2007, 04:11 PM   #1 (permalink)
preilly44
How do you remove the inside of the radio door?
I have the JVC NX-KD5000 GPS radio and I can't quite get it to fit to the point where I can close the radio cover door. Does anybody know how to remove the credit card holder? I believe if I can remove that I'll be able to close the door.
I was advised to use a flat head screw driver but I didn't have any luck with that....if that is the only way to do it, is there a certain place I should try prying it from?
Thanks in advance!
Patrick
preilly44 is offline   Reply With Quote
Old 03-27-2007, 11:14 AM   #2 (permalink)
Dr. Jimbo
Top Always Down
Dr. Jimbo's Avatar
How'z about using a Dremel tool if you want to cut out the little holders inside the radio cover. I'd be real careful, 'cuz you only have one shot at it. You would need the right cutting or grinding attachment and do it at the proper speed (check the manual that comes with the Dremel). I'd make sure to cover the radio (and wear safety glasses) because little bits of plastic will be-a-flyin'.
Jimbo
2000, 2004, 2005, 2008, cover, door, honda, install, nxkd5000, radio, removal, remove, removing, s2000, stereo
How to remove headlight assembly? 2000S All Other Honda S2000 Related Discussions 5 02-12-2008 07:57 AM
technical color specs-matching 07 radio door in 02 ger2k Interior / Audio / Electronics 2 01-20-2007 01:13 AM
Radio lid: how to remove/install? Tim Gedney Interior / Audio / Electronics 1 10-28-2006 10:18 AM
radio door gregs01 All Other Honda S2000 Related Discussions 2 08-18-2006 02:58 PM
How do you remove the side markers? blk95civic All Other Honda S2000 Related Discussions 1 08-16-2004 08:06 AM
