Old 11-22-2007, 01:03 PM   #1 (permalink)
zyid
98 ls400 89 camry
Exclamation Radio Code Help, CDV?, and 30k Maint.
1st Radio is asking for a code, the car does not have a manual I viewed the thread on this topic and i didn't understand it fully. Please help
2nd Pros and cons with the clutch delay valve in and out, also does anyone have any detailed instructions on how to remove the cdv?
3rd Is there anything specific, maintenance wise, that needs to be done at 30k miles?
I would greatly appreciate it if you veteran s2k owners could help out the newb. Also if you could tell me where the secret compartment is you could email me and nobody would know you told me. Thought i would try lol, still searching.
Thanks again, zyid
zyid is offline   Reply With Quote
Old 11-22-2007, 01:08 PM   #2 (permalink)
PM for the quick, cheap, and easy way to get your code.
Change your oil/ filter, tranny fluid, clutch fluid, diff fluid and brake fluid while you are at it. The brake fluid isn't as important as the others to change at your mileage, but you have the car up in the air anyway. Change the engine air filter and cabin air filter as well.
Ummmmm, no way, you are on your own here.
Old 11-22-2007, 01:19 PM   #3 (permalink)
zyid
98 ls400 89 camry
what does pm mean?
Old 11-22-2007, 01:24 PM   #4 (permalink)
zyid
98 ls400 89 camry
also what are the weights and fluid types for the s2k i like to use mobil1 so if you would tell me the weights id appreciate it
Old 11-22-2007, 01:49 PM   #5 (permalink)
PM means Personal Message.
Weights are (what I use, but others may use something else):
10W30 Mobil1 for oil
Honda MTF for the tranny
Diff is a 90 wt. Something like this:
http://www.hardtopguy.com/store/prod...2&cat=0&page=1
Brake fluid is a boiling point of over 600, but I track mine, so you may not need that much temp.
Filters (oil/ engine/ interior) can be found various places- Honda, HTG (the link above) and elsewhere.
Old 11-28-2007, 08:09 AM   #6 (permalink)
Gray Ghost
Gray Ghost's Avatar
You can call the honda dealer and tell them that you replaced your battery and lost the coding on your radio. Give them the vin # off your car and they can tell you the code to use.
Gray Ghost is offline   Reply With Quote
